cutting required for tow hooks on a 97 stock bumper? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > cutting required for tow hooks on a 97 stock bumper?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 09-28-2007, 12:16 PM   #1
Dang12457
1997 XJ Cherokee
This is probably too simple a question but I want to get a handle on what I need to anticipate in adding these.
I have a 97 sport and need to start adding my recovery points. Will I need to cut much of the plastic away to add my tow hooks? There are some cut out's directly beneath the bemper extensions, but don't know if those will accomodate the hooks.
Thanks for the feedback.
Dang12457 is offline   Reply With Quote
Unread 09-28-2007, 12:26 PM   #2
CharBroiled
my 2000 already has the cutouts for the existing fog lights (obviously) plus holes where the factory tow hooks would be. so factory at least should go right in.. not sure about others.
there are a lot of pics floating around the forum of folks who have cut holes for tow hooks when their jeep didnt have factory ones or put heavier ones on instead.. im sure someone will post some ideas.
[COLOR="DarkRed"]2000 Cherokee Sport 4.0L Selec Trac[/COLOR] - mine - for occasional wheeling
[COLOR="DarkGreen"]2007 Patriot 2.4L FD I 4x4[/COLOR] - wifes - doomed to rarely leave the street
CharBroiled is offline   Reply With Quote
Unread 09-28-2007, 12:46 PM   #3
itasor
2009 JK Wrangler
You don't have to cut anything, but some people cut off the bottom piece of where the pre-existing tow hook holes are. Not sure why, maybe if they mount them upside down they do that?
itasor is offline   Reply With Quote
Unread 09-28-2007, 01:28 PM   #4
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
if the knock outs in the air dam aren't already, uh, knocked out, you'll need to cut them out.
Jason West - Jeepin.com | JeepinOutfitters.com
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Unread 09-28-2007, 10:21 PM   #5
Dang12457
1997 XJ Cherokee
Thanks for adding the pic Jeepin.
Do you need to take the bumper off entirely or can you support the bumper with jack stands and do one at a time to make the job less involved?
Unread 09-28-2007, 10:25 PM   #6
lost honda pro
1997 XJ Cherokee
i suppose in theory you could do one side at a time, but i think it would save time an effort by pulling the whole thing, bolting up the parts, and reinstalling, rather than lying upside down and finagling bolts and nuts up under the bumper.
lost honda pro is offline   Reply With Quote
Unread 09-29-2007, 07:23 AM   #7
Vendor
1995 XJ Cherokee
you need to pull the bumper off to do the install. Both bumper brackets have to be unbolted from the body/frame anyway, so might as well do them at the same time and pull the bumper off and clear up that work space.
