Custom Spare Tire Roof Rack Mount [writeup/pics]
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | ||
Hey guys,
Got sick of having my 31" spare sitting flat in my trunk, and decided to fab something together to mount it to my Coleman roof rack. Parts: 3/4" U-Bolts w/Lock Washers - 4 @ $0.91 = $3.64 4" Beam Support for Concrete = $13.69 TOTAL (After Tax) = $18.73 ![]() ![]() I had to use a 1/4" bit to make the holes on the beam support big enough for the U-Bolts to fit through: ![]() After that I attached the beam support to the rack using the u-bolts. It wasn't an exact fit, so the beam support legs bent out a bit, and the rack rails bent a bit too: ![]() ![]() ![]() Then I put the tire up there. To tighten it down, I used the OEM plastic semisphere that used to hold my tiny spare inside the car. I just took a 3/4" wood bore to it to make it fit, then I secured it down: ![]() The Finished Product: ![]() For less than $20 I think it works pretty well. It's secure and doesn't move at all.
| 1992 White XJ LaredoPARTING OUT | |___NEW JEEP___| 98 XJ Sport | 4.0L | AW4 | 3" BB Lift | 31" BFG A/T |______________| Quote:
#2 |
hey thats a cool idea....
#3 |
I keep seeing different ways of doing this haha. I'd probably clean the rim out as good as possible cause as soon as that rain hits it, all the nasty black dust is going to get all over your white jeep!!!
The Pop Top Camper Thread CLOTHIER TRANSMISSION & TRACTION PRODUCTS Tire Chains for 31" up to 49" tires Transmission Adapter Kit, GM/Chevy "4 bolt main" to SAE #2 |
#4 | ||
#5 |
Not to hijack, but...
I thought about going this route, but then thought about what if you didn't have your tire in there for a while and you'd have that vertical bolt just chillin up there... so I put the bolt side on the rack: ![]() |
#6 |
Wow, You guys might inspire me to get rid of the ratchet straps holding my 35 to my wildness rack.
![]() I keep wanting to build something like a fold up crane to lift /lower that monster from the roof rack. It to me and my daughter standing on the back of a F/S chevy to put that 35 up there. Chris.
95 Cherokee SE 4.0, 5-Spd, 8.25; 6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack Rock Sliders, K&N Panel Air filter, PSC steering box, I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$ |
#7 |
![]() Maybe something like this that just rotates on a top rail? Idk, just thinking outloud with my paint skills :P
#8 | |
That's cool but a 35 would still be a bear. I was thinking something like a receiver set up mounted vertically on the floor of the rack. This could serve as a mount for the spare and a place set a swing arm with a cheap small 12v winch. the winch could be easily stowed inside. the swing arm removed from the receiver and mounted to the rack floor or on the rails going round a corner. I know I'm a hi-tech redneck. ![]() Chris.
#9 | |
I like that idea for putting the bolt side on the rack itself, but when i saw that post thingy at home depot, i figured it'd be stronger than anything i was planning to make. and i just painted the inside of the rim, so it's sitting on the floor, and without a tire it kind of looks like a lightning rod up there
#10 | |
The Bike Guru
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have." MY BUILD THREAD: http://www.jeepforum.com/forum/f22/build-thread-year-later-01-xj-643365/ My Photography Paul Lehr's Flickr |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
