#1 | |
Custom made Rock Rail/steps
Just wanted to show you guys my rock rail steps.
There is more on my site. Sorry about bad pics.
The meaning to life is to live, So Go Live....Offroad :o) [COLOR=red]******************************************[/COLOR] [B][U]1998 Cherokee, 2 Door, Black.[/U] [/B] 4.0 L Power Plant, NP231 Transfer Case 32" BFG All Terrain Tires on 15"x7" "Grizzy" Jeep wheels Helix TB Spacer with K&N Replacement filter. C4x4 Rear Bumper/Tire Carrier with hitch and towhooks :) DPG Rock Attack XJ Gas Tank Skid Plates RE 4.5" lift - With 1" 5/8 Spacer up front, and 1" Spacer and 3/8 shim in back. So over 6" of lift. |
#2 |
Looks good!
How much did they end up costing you?
1992 Cherokee Briarwood 4.0L ARB Bull Bar/Warn XD9000 4.56s D30/ARB D44/Lockrite with Discs 4" OME/Teraflex Lift with 33x12.5 BFG M/Ts KOR Rock Rails and JKS Discos |
#3 |
Broke Bogger
Looks grrrreat
Actually they are almost identical to mine, also custom made
Matt __________________ 97 XJ - Black Sport, 4.0L AW4, D30 and 8.25 6" Skyjacker/RE, 33x13.5 Swamper LTB Cracked Frame, good for steering!!! MY XJ PICS |
#4 |
I bought all of the steel ($128)to build mine last week......then the axle fell off. I should have mine done soon. Looks good!
John
87 XJ Larado, w/ 95 XJ(4.0HO engine), 3" Procomp Lift, on 30"x9.5" BFG AT's (My DD) 90 XJ Larado,34x10.50 LTB's, RE 5.5 Extreme Duty Full Skids, Custom Rock Rails, Aussie Locked Dana 44 Rear, Posi'd D30 up front ....running 4.56's! (Trail Rig) |
#5 |
hay bro did u mount them to the pinch, or just the frame¿ And how did u atach them to the frame? post some picks of the mounts if u could.
Thanks |
#6 |
very nice man. yea id like to see how you mounted those suckers. btw what the heck is that plastic hanging near the fender flares. are those mudflaps, WHY!!!!!
used to have my project jeep.... had to sell her and now i just dream of the future. |
#7 |
They look good, but I would consider another leg that is in the middle of the Rocker. It would be non-sense to drop off a ledge and damage yor rocker with the guard. Just an idea, but they look awesome.
#8 |
Cool thanks guys for all the compliments.
Verrive- they cost me $700 Canadian /installed. (That’s about $550 USD) Keep in mind I had them made the way I wanted em. And Tomkin ones sell for $499 out here. Problem with those is that they would not work with my front drop brackets, and their pinch weld mounting point is weak. MSHarnett- Cool! You’ve got pics? johnh2os- Axle fell Off????? OMG Damn. Can't wait to see pics of yours.batilzown- Mine attach to the frame and pinch weld. (Ill post some pics) 98Sport- Sorry to disappoint you and anyone else. Problem is to get to nice trails out here you have gravel roads with nice sharp gravel rocks that peel paint in one shot ( or you can drive 10 MPh or less). Plus it rains here ALOT. so rust is issue with chipped paint. I have to paint the rockers with something like rino liner. Once that is done ill take them off just for you Ctavel - I’ve thought about an extra leg in the middle. I just wanted to keep wait down. My original plan was to get Detours rock rail/step/body stiffeners. Problem with em was they are 100 Lb together where mine are 60 Lb. Ill get some more pics or diagrams online soon for you guys.
#9 | |
Broke Bogger
#10 |
Hi, noob here. What is a rocker?
1998 XJ Sport Completely Stock Suspension TB spacer + cone 30x9.5x15s |
#11 | |
Broke Bogger
EDIT: here is my passenger side rocker, dented from one of those jumping rocks, haha. Oh yeah, they also help block some muds from splashing on the body ![]()
#12 | |
Couldn't say it better my self. Damn nice battle scar. ![]()
#13 |
Ok drew up a diagram hehe.
And here are the other pics. If you look closely at the rocker you can see the touchup paint and the poor paint job Chrysler did. I hate rust. On this pic its how it holds the pinch weld Ahh yes the blurry full view Hope this helps answer your questions guys.
#14 |
Impressive mounting solution. How does it hold up? How well does it work as a step? Also, what's the main rail out of? 2x4 box tube?
Instead of welding nuts to the loose piece, why not drill and tap them, then a locknut for extra measure?
88 MJ: some assembly required 98 XJ 2dr: little lift, lotta skidplate www.wnyoffroad.org |
#15 |
i no all about how it holds up at the pinch.
But what did u guys do at the frame. It looks like is bolted up. Did u put long bolt threw the frame and out the other side w/ a nut? Or self tappers? Or tap the frame and tighten a bolt in? What did u do? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
