Quantcast custom built roof rack - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > custom built roof rack
Old 01-19-2006, 05:55 PM   #1
x550x
1960 CJ3B
I am planning on fabricating a steel roof rack.
It is going to be approximately 65"x45" and it will mount to the gutters.
Does anyone know what a good wall thickness for the steel would be?
I want it to be strong any yet not weigh a ton.
I am planning on using 3/4" square stock.
Thanks!
FOR SALE - 1960 Willys CJ3B - Odd Fire V6 - T177 - Dana 300 - D30 - D44 - 33x12.50 Super Swampers
x550x is offline   Reply With Quote
Old 01-19-2006, 05:59 PM   #2
olds442
whenever its done id like to see pics
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
olds442 is offline   Reply With Quote
Old 01-19-2006, 06:29 PM   #3
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
Thanks!
I used 3/4 square tubing for mine along with some steel plates for light mounts and expanded steel for the floor. I have some measurements on the link below if you need them. I also have pics on my signature link.
http://www.jeepforum.com/forum/f11/roof-rack-info-181015/
If you need rain gutter brackets and rods here is a place to get a set of 5" high mounts. I'm running 5" so I can wash under it.
http://www.a1-autoracks.com/rain-gutter-roof-racks.html
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
Jeep Pic's
coppertop71 is offline   Reply With Quote
Old 01-19-2006, 06:36 PM   #4
Jeepernick
2008 XJ Cherokee
Mine is custom... one of a kind
Good Luck
Jeepernick is offline   Reply With Quote
Old 01-19-2006, 06:44 PM   #5
x550x
1960 CJ3B
Here are my rough plans. There are no light tabs or mounts shown. I will probably add them during the build.
What do you think? Would you change anything?
Old 01-19-2006, 06:47 PM   #6
x550x
1960 CJ3B
Thanks for the link.
I really need to know what wall thickness to use. It needs to be a balance between strength and weight.
Old 01-19-2006, 07:04 PM   #7
coppertop71
1990 XJ Cherokee
I'm not sure but it was proably 1/16th square tubing. The fact that its tubing help the strength factor and allows you to loose wieght by going thin.
Waht the plans say for your hieght on the sides and how are you doing the corners?
If you can find use of a tube bender think about cutting the corners into angle to get away from the square boxy look. What if the hieght of the sides. I believe mine is 4" deep and I can say I wished now I would have went 1-2 more inchs. I put light puffy stuff like tentage, tarps, pole bags on mine then use the inside for the heavy stuff. Anyway that stuff just kinda rolls over the sides between the straps I think a few inches more and it would look more secure.
Mods
Jeep Pic's
Old 01-19-2006, 08:38 PM   #8
NYCXJ90
1990 XJ Cherokee
I used 16 gauge 1" square tubing, I think my dimensions are like 64"x54"x6" (depth):
Gonna add some more front to back bars and tire and hi lift mounts as well as integrating my light bar onto the rack itself.
As of right now I can stand on any one of those bars and bounce up and down with VERY little flex.
'90 XJ Laredo /33"X12.5" Retreads/ RE 3.5" Super Ride
NYPD Jeep Club Member #2
Marine Corps Jeep Club Member #3
So I tell the swampdonkey to sock it before I give her a trunky in the tradesman's entrance and I have her lick me yardballs.
NYCXJ90 is offline   Reply With Quote
Old 01-19-2006, 09:33 PM   #9
x550x
1960 CJ3B
Thanks for the advice guys. I did some searching and found that most companies use 3/4" 16 guage steel. I will probably use 16 or 14 guage.
I am planning on making the basket about 5" deep. I don't really want to go much taller than that.
If I don't go with the radius on the corners, I will probably do a 45 degree octagonal looking thing to keep it from being a perfect rectangle.
Glock Forum
