Quantcast custom and aftermarket front bumpers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > custom and aftermarket front bumpers
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 11-15-2007, 03:15 PM   #1
B-Radical
1993 XJ Cherokee
I'm sorry, I know this is the tech section, but I have a thread in the pic request forum and am getting no responses. I thought I'd get more XJ traffic here.
I'm looking to fabricate my own front bumper and I would like to see some pics of what others have done. I will not copy anyones custom design as I like to be original myself, but I would like to see some pics please. and to keep it on the tech side, maybe a little explanation of how you did it, or of the bracketry not shown.
Thank You
Brad
[url=http://www.myspace.com/b_radicalcustoms][B]93 Cherokee Country/Classic[/B] Black/Green, 4.0L HO ATX 4x4 SUV[/url]
[B]98 Cherokee Classic RIP[/B] Black, 4.0L ATX 4x4
[url=http://www.myspace.com/b_radicalcustoms][B]94 Probe GT-ZE[/B] Black/White, 2.5L J-Spec V6 MTX fully pimped exterior 14.7 e/t naturally aspirated[/url]
B-Radical is offline   Reply With Quote
Old 11-15-2007, 04:00 PM   #2
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
what part of building a bumper don't you consider 'tech'?
Jason West - Jeepin.com | JeepinOutfitters.com
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Old 11-15-2007, 04:00 PM   #3
jfiscus
1993 XJ Cherokee
I know it's a Grand Cherokee, but I don't see how the design wouldn't be 99% the same for an XJ:
More pics here:
http://s25.photobucket.com/albums/c72/jfiscus/Custom%20Fab/ZJ%20Bumpers/Winch%20Bumper%201/
I used 5x5 3/16" square tube for the body & 3/8" for the winch plate.
I think the total length of the solid rectangular piece required was 84" (I had two shorter pieces & had to weld on the side extensions). All other pieces were 3/8" flat stock.
97 ZJ Limited, all power V8 AWD (wife's DD)
93 XJ Country – 32" TSL Radials, 4.5" Rough Country Lift [url]http://s25.photobucket.com/albums/c72/jfiscus/93%20Jeep%20Cherokee/[/url]
91 XJ Laredo – 33x15.5 TSL SXs, Homebrew 3" lift [url]http://s25.photobucket.com/albums/c72/jfiscus/91%20Jeep%20Cherokee%204-Door/[/url]
Local to Cincinnati, Ohio? Check out our club! [url]http://www.terrainstompers.com[/url]
jfiscus is offline   Reply With Quote
Old 11-15-2007, 06:05 PM   #4
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Use this diagram to start your bumper mounting brackets. --http://www.twisted-halo.com/digicam/xj/Bumper%20mount.pdf --Extend them as long as needed to fit your design. Look at bumpers in online stores and copy the features you like.
homebrewed bumper write-up -->> Clicky here
Here is mine -
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 11-15-2007, 07:17 PM   #5
Dickydubs
First off double check all the measurements on that drawing linked above, I used that and a few holes were off. I was going to draw up a correct arrangement but I lost the sketch since I moved to CO and haven't had the time.
Below are pics of the Bumper I designed and my brother fabbed up. It is all 1/8" sheet metal. The brackets should be at least 3/16", preferably 1/4". My brother used a cnc plasma cutter to cut out the pattern and then a press brake to bend it and mig welded it together. Most people don't have access to the press brake so you could make it multiple pieces and weld them all together. Also there are gussets welded into the corners between the Unibody tie in brackets and the main part of the bumper.
Building your own is def. the way to go. Good luck
97 sport 4.0 5spd, command trac
stock height with General Grabber AT2
sony HU w/ aux input, infinity 5 1/4" and 6x9"
Dickydubs is offline   Reply With Quote
Old 11-15-2007, 10:09 PM   #6
SmrtJustin
Originally Posted by CJ7-Tim
Use this diagram to start your bumper mounting brackets. --http://www.twisted-halo.com/digicam/xj/Bumper%20mount.pdf --Extend them as long as needed to fit your design. Look at bumpers in online stores and copy the features you like. Here is mine -
CJ7-Tim, I really like your front bumper. I wish someone made one like it that I could buy, since I don't have the tools or the know-how to fabricate my own.
1999 Cherokee Classic
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
OME CS035RA Heavy Load Rear Leafs (~3.25")
RE 1334 Front Spacers (~2.5")
P.O.R.C. HD SYE
30x9.5 General Grabber AT2s
B&M SuperCooler 70255 and Temp Guage
SmrtJustin is offline   Reply With Quote
Old 11-15-2007, 11:13 PM   #7
mason_msw
x2 i like that as much or more than any bumper i have come across so far.
mason_msw is offline   Reply With Quote
Old 11-16-2007, 12:08 PM   #8
B-Radical
1993 XJ Cherokee
Originally Posted by Dickydubs[URL=http://good-times.webshots.com/photo/2370646390102387748bCauiI
[/URL]
This is pretty close to what I was visioning mine to be, except...
Does anyone have pics of a bumper with a winch and lights?
oh- I do have access to a plasma cutter, and a brake
Old 11-16-2007, 01:13 PM   #9
Jeepernick
2008 XJ Cherokee
More pics here:
http://s25.photobucket.com/albums/c72/jfiscus/Custom%20Fab/ZJ%20Bumpers/Winch%20Bumpe01/
WOW that is godly..... how much does it weigh? 400lbs
More pictures on my JF Gallery
Specs:
3/16" plate to cover the 2x2x3/16" tube frame and 1/4" where the winch will rest someday
the singer is 1.5" .25" DOM
Jeepernick is offline   Reply With Quote
Old 11-16-2007, 01:18 PM   #10
nudosimmons
its made of 2x5 tubing, its simple, light and gets the job done. tabs go through and are welded to the 1/4" mounting paltes
1988 xj 4.0, ba-10, np231
trimmed fenders
3in lift, 33s
herculinded interior
custom bumper
http://www.jeepforum.com/forum/f11/update-my-xj-362812/
nudosimmons is offline   Reply With Quote
Old 11-16-2007, 01:27 PM   #11
Jeepernick
2008 XJ Cherokee
one more for fun
Old 11-16-2007, 01:53 PM   #12
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Old 11-16-2007, 02:23 PM   #13
Dragnz24
I will try to get some clear pics tonight of the front bumper we built for my XJ. Even though it is not 100% done it still looks good. BTW I suggest getting Nates XJ bumper brackets if you dont feel like making your own. He does not have them on his site but he will sell them.
1991 XJ, 4.0L HO, 3in rustys coils, 3 in. block in rear soon to be replaced, on 33x12.5 , stock dana 30&35 open front and rear
http://www.gulchesorvpark.com/
Dragnz24 is offline   Reply With Quote
Old 11-16-2007, 03:05 PM   #14
mason_msw
I'm really glad you mentioned that, I looked through his fabricators parts and didn't see them and was a little dissapointed. If you purchased them do you mind me asking what they ran you?
Old 11-16-2007, 03:28 PM   #15
Dragnz24
The cost the same as the rear brackets. I think that was 40.00
Glock Forum
