Custom 3 link and Waggy 44 swap into my XJ - Page 7 - JeepForum.com
post #91 of 379 Old 08-10-2011, 03:09 PM Thread Starter
2doorxj
2doorxj's Avatar
The whole front end is basically finished, the only things left are to bleed the brakes, install my hubs, which should be here in about an hour, fill the axle with fluid and put my HD dif cover on.
For the whole jeep to be done, i need to install my rear pads, wheel cylinders and spring kits, bleed the brakes, fluid, do my rim stiffeners, and install my wheel spacers in the rear.
I did a driveway allignment with a tape measure, i set the toe in at about 1/8 inch, the caster is about 4 degrees, the trackbar was eyeballed straight. Im going to have it done professionally once its on its wheels again.
Enough talk, heres a couple pics.
My jeeps a porn star:
2012 Cherokee of the Year
2doorxj is offline
post #92 of 379 Old 08-11-2011, 07:10 AM
dukie564
1995 XJ Cherokee
wow looks great man.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #93 of 379 Old 08-11-2011, 08:43 AM
94chb
looks to me like your are going to need longer brake lines
94chb is offline
post #94 of 379 Old 08-12-2011, 01:06 AM Thread Starter
2doorxj
2doorxj's Avatar
In that pic, the brakeline curls around as well, theres actually plenty of slack.
2doorxj is offline
post #95 of 379 Old 08-12-2011, 10:33 AM
fedx95
1993 XJ Cherokee
WAITING FOR A PICTURE WITH THE FINISHED PRODUCT.
fedx95 is offline
post #96 of 379 Old 08-12-2011, 10:36 AM
B2CARPEN
Man I commend you, great work! I'm just now pulling all the pieces together for my JK D44 swap and TNT LA install, I'm excited!
Founder of
B2CARPEN is offline
post #97 of 379 Old 08-15-2011, 07:15 PM Thread Starter
2doorxj
2doorxj's Avatar
Its driveable! The brakes are spongy as hell, and all the airs out of the system, as well as the rear brakes are adusted properly, and it needs an allignment, especially more caster.
Any clues as to why the brakes are spongy?
2doorxj is offline
post #98 of 379 Old 08-15-2011, 08:06 PM
silbotta
very nice
94 YJ
06 Cummins
silbotta is offline
post #99 of 379 Old 08-15-2011, 08:55 PM
The_Blacksmith
1993 XJ Cherokee
bad booster or vacuum lines on the booster, or a failing master cyl are my only gueses. re check for leaks. and re bleed.
Thanks Chris!
The_Blacksmith is offline
post #100 of 379 Old 08-15-2011, 09:02 PM
aircruiser
aircruiser's Avatar
damn man your **** makes me miss my xj. looks good man and nice fab work i like the suspension setup. looks 10x more bad *** with the soft 8s have you thought about weld on beadlocks?
aircruiser is offline
post #101 of 379 Old 08-15-2011, 09:24 PM Thread Starter
2doorxj
2doorxj's Avatar
Haha thanks a lot bro, I'm not sure wht I'm going to do with the wheels yet.
2doorxj is offline
post #102 of 379 Old 08-15-2011, 09:38 PM
aircruiser
aircruiser's Avatar
i take it you really like the MTR/Ks? i was gonna get some but went with duratracs. im doing a 44a swap and re-gearing my zj to 4.56s and doing a 4.5" lift with long arms and IRO OTK and bilstiens but after seeing jeeps with similar setups, i may eventually go with 35s and i love my duratracs dont get me wrong, but by then im hoping to make it more of a wheeler and need something a little more dedicated.
post #103 of 379 Old 08-15-2011, 10:12 PM Thread Starter
2doorxj
2doorxj's Avatar
Lol, their my tire of choice, this is my 3rd set, i like them better than the km2s, I've had 2 sets of those
2doorxj is offline
post #104 of 379 Old 08-16-2011, 02:12 PM Thread Starter
2doorxj
2doorxj's Avatar
Flecks is good
Needs bumpstops
limiting straps
front fenders trimmed
longer brakelines
2doorxj is offline
post #105 of 379 Old 08-16-2011, 02:46 PM
aircruiser
aircruiser's Avatar
flexy. are you sticking with the ax-15 or going to do an AW4 swap? i cant believe how much easier it is to wheel with an auto haha. i miss the 5 speed for the street but cant beat an auto crawling..atleast IMO
Need help with custom 4 link rear b_wern XJ Cherokee Technical Forum 5 01-24-2010 11:57 AM
Custom Waggy taillights. Let me know what you think skyjacked94xj XJ Cherokee Technical Forum 35 03-10-2008 08:02 PM
Waggy Axle Swap Brake Problem godplayer XJ Cherokee Technical Forum 5 05-16-2007 05:41 PM
Rear Grand Waggy 44's good swap? Cox89XJ XJ Cherokee Technical Forum 1 04-03-2006 07:13 PM
Custom Suspension Link Tech mississippi_xj XJ Cherokee Technical Forum 1 07-15-2004 03:34 PM
