Custom 3 link and Waggy 44 swap into my XJ - Page 5 - JeepForum.com
post #61 of 379 Old 07-12-2011, 11:13 PM
justanotherjpr
Looks good. How big is the gap between the inner frame and the uca mount? If you can stand 1/8", i would slip some 1/8 flat stock between the link mount and the frame. Weld the flat stock to the frame and the link mount to the flat stock. Seems that it would spread the load out better.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #62 of 379 Old 07-13-2011, 03:20 PM Thread Starter
2doorxj
2doorxj's Avatar
The gap is very slim, it looks bigger than it is in the pictures, but i like that idea.
2012 Cherokee of the Year
2doorxj is offline
post #63 of 379 Old 07-16-2011, 12:46 AM Thread Starter
2doorxj
2doorxj's Avatar
Got the stiffeners completely welded in, the only thing is im concerned about small gaps between the stiffeners and the frame rail, could i seal the thing up with some seam sealer? You guys think it would hold up and stop water from getting between the frame and stiffener?
I mocked up my control arms:
Steering and trackbar mocked up:
Set my caster at 6 degrees when the coil buckets are at 0, completely burned in the control/coil bracketry and the upper control arm link tower. Painted it, rustoleum brush on, semi flat
My DOM is here, so i have basically everything i need to finish the jeep, oh yeah, i also need som etype of flex joint at the axle, poly joints will NOT work, because the coil brackets are mounted wider than my control arm brackets, so rather than cutting the coil brackets back off, and playing with those until the point directly at the brackets on the frame, ill just order some type of flex joint, whether it be a heim, currie johnny joint, or a ballistic joint. Besides im sure a smidgeon of misalignment wont do much.
Im leaning towards ballistic joints because i could trade my poly bushings in and get those? Anyone out there ever used ballistic joints? Id rather stay away from a heim at both ends.
2doorxj is offline
post #64 of 379 Old 07-16-2011, 01:20 AM
Timo_90xj
Timo_90xj's Avatar
Nice work!
I've been wondering about the same thing with frame stiffeners on how to fill the gaps and prevent water from going between the uniframe rails and stiffeners. Living in an area where salt is used pretty extensively during winter, it would rot the stock uniframe pretty damn quickly.
edit: As you wrote, it probably is a good idea to weld the upper mount to the inside of the frame rail. Those link mounts take a beating, so any extra support is a goood idea IMO.
***Under construction***
Timo_90xj is offline
post #65 of 379 Old 07-16-2011, 09:59 AM
Brookhart63
This is looking great! Any particular reason your sticking to leaf springs and drum brakes in the rear?
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
post #66 of 379 Old 07-16-2011, 10:41 AM Thread Starter
2doorxj
2doorxj's Avatar
haha, a rear 4 link is not cheap/easy to do, i figure im getting some good practice with the 3 link, and down the road ill do a 4 link rear.
As far as drums in the rear, those will be changed to discs, but right now im just worried about getting this thing on the road.
Thanks guys!
2doorxj is offline
post #67 of 379 Old 07-16-2011, 11:34 AM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
nice work.
im liking this build
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #68 of 379 Old 07-16-2011, 05:33 PM
86cherokeek20
1986 XJ Cherokee
whats the price on ur three link as in the brackets coil buckets joints and DOM tube plannin on doin this on mine as well as 4 link in the rear
Bruno the jeep-boatsides, 14b, dana60, linked, tubeframed-exo to come-build in progress!
tow rig-92 f150 with 351 and 4 spd
86cherokeek20 is offline
post #69 of 379 Old 07-21-2011, 11:44 AM
TYphoonXJ
Originally Posted by 2doorxj View Post
I drilled two 7/8s hole on both side of the frame where the old crossmember stud/nut used to go. That was NOT fun, i broke one of my expensive step drill bits, and a couple other drill bits. I was using my dads super heavy duty milwaukee drill, that damn thing almost broke both my wrists multiple times.
SAME HERE. I had to drill 2 giant holes for my RC Long Arms...whatta *****. I was drilling with my dads milwaukee (how ironic) and mym friend even had a grip on it too and I thought for sure I broke my wrist when it grabbed. Ya live and learn I guess lol
Looks awesome man, what welder are you using?
96 XJ. RC 4.5" Long Arm with 31" Firestone Destination MT's.
TYphoonXJ is offline
post #70 of 379 Old 07-21-2011, 11:54 AM Thread Starter
2doorxj
2doorxj's Avatar
Thanks! And yea, those drills have some SERIOUS torque.
The welder is a 220v 155a Marquette with 75/25 gas.
My dad got the welder out of the body shop at his job, they gave it to him for free
2doorxj is offline
post #71 of 379 Old 07-21-2011, 05:00 PM
3vze28
lets see some more progress pics bud.
disassembled....looked at....reassembled with some goodies...
Build Thread--->
3vze28 is offline
post #72 of 379 Old 07-25-2011, 07:38 PM Thread Starter
2doorxj
2doorxj's Avatar
Okay, but for some reason, i forgot about this thread.
I finished building all of the control arms, and the axle is bolted into the jeep. Of course i have no pics, nor will i until saturday.
Now, heres the things i want/need to get done:
Axle side panhard mount (still trying to think of a way to make one)
I want to drill two holes on the frame, by the upper link mount, run the two bolts through the frame, just for some more support for the mount.
Swaybar mounts
Im going to ditch the ballistic way of mounting the coils, i want to make my own bumpstop tube, that welds to the coil baseplate that will also hold the coils in place, and then hold the coils down with a stock style coil retainers. I know that the interior diameter of an XJ coil is 4 inches, so id like to go down to home depot and see if they have any plumbing pipe with an OD 4 inches. If you dont understand what im saying, you soon will, once i get back from vacation, and i can get back to work.
I also need to do my rear brakes and brake lines.
2doorxj is offline
post #73 of 379 Old 07-25-2011, 08:30 PM
foggybottombob
I know you mean you want a way to hold the spring in place on the buckets. I used Ballistic Fab's parts and the spring hold down plate was just too flimsy. I think it was 1/4" steel. Mine bent and I bought some 3/8" steel and made substitutes which are still working.
foggybottombob is offline
post #74 of 379 Old 07-25-2011, 09:40 PM Thread Starter
2doorxj
2doorxj's Avatar
Have any pics?
Thanks fbb
2doorxj is offline
post #75 of 379 Old 07-27-2011, 06:09 PM
1 ton yj
1 ton yj's Avatar
Any reason you put the upper on the long tube side, instead of over the pumpkin?
We put the same axle in my friend's YJ last fall with a 3 link/panhard. You can kinda see the bracket in this picture (ignore the hi lift handle tie rod).
The offset bracket came from one of my friends who owns a shop in Palisades Park. If you want one I can put you in touch with him.
1 ton yj is offline
Need help with custom 4 link rear b_wern XJ Cherokee Technical Forum 5 01-24-2010 11:57 AM
Custom Waggy taillights. Let me know what you think skyjacked94xj XJ Cherokee Technical Forum 35 03-10-2008 08:02 PM
Waggy Axle Swap Brake Problem godplayer XJ Cherokee Technical Forum 5 05-16-2007 05:41 PM
Rear Grand Waggy 44's good swap? Cox89XJ XJ Cherokee Technical Forum 1 04-03-2006 07:13 PM
Custom Suspension Link Tech mississippi_xj XJ Cherokee Technical Forum 1 07-15-2004 03:34 PM
