Custom 3 link and Waggy 44 swap into my XJ - JeepForum.com
post #1 of 379 Old 05-31-2011, 05:47 PM Thread Starter
2doorxj
2doorxj's Avatar
Found some wagoneer 44s on craigslist, they were out of an '89, but they had been swapped into a YJ. The front has warn lockouts, 4.88 gears, and a mini spool. The rear has 4.88s and a mini spool. I paid 800 for the two of them. Oh yea, the guy threw in a 3/8s hd dif cover too
Here are the axles when i first picked them up:
Gears:
Okay, so here are my plans.
For the upper link ill be using:
-7/8s ruff stuff heims
-1.5 inch ID .25 wall DOM, probably going to be sleeved, i need to do more research.
Lower links
-(2) 1 1/4 ruff stuff heims
-(2) ballistic fab poly bushings
-1.5 ID .25 wall DOM, possibly going to be sleeved with 2 inch ID DOM, not sure on the width yet. I still need to do a little more research.
Axle Bracketry
- Ballistic Fab Coil buckets, with LCA mounts, and shock mounts. http://www.ballisticfabrication.com/Link-bracket-coil-spring-shock-mount-combo_p_1461.html
- Im going to be re-using a trackbar mount that i have, and most likely the trackbar itself too.
-Barnes 4wd, adjustable link tower. http://www.barnes4wd.com/product_info.php?products_id=2400
"Frame" Bracketry
- Ballistic Fab link mount http://www.ballisticfabrication.com/Heavy-Duty-Frame-Link-Mount_p_1511.html
- Ballisitc Fab upper/lower link bracket http://www.ballisticfabrication.com/Dual-frame-link-mount_p_1164.html
They will both be welded to HD offroad engineering Frame stiffeners.
Steering
-JCR OTK knuckle steering, and eventually chevy flat-tops and true high steer.
Im planning on a ~26' lower and a ~31 inch upper, Should keep the pinion pointed at the output on the t-case even at full droop. Around 8 inches of vertical seperation at the axle, and around 3-4 at the frame.
For all of the welding, ill be using my Marquette 220v with 75/25 gas, and .030 wire.
Practice welds:
I have all of my "junk" on order, i hope to start fabricating by this weekend.
The only progress i have on the axles, is that they are both stripped of their old YJ SOA brackets, they still need to be ground down to bare metal though.
Grinding/ cutting sucks in this weather, all the sparks stick right to my sweaty skin.
I guess ill throw in a before shot of my XJ, once im done, its gonna have 35 inch MTR/kevlar, and soft 8s (the official rim of jeepforum)
All comments, questions, criticism, concerns are welcome
2012 Cherokee of the Year
2doorxj is offline
post #2 of 379 Old 05-31-2011, 05:52 PM
B2CARPEN
Sounds like an excellent start for a nice axle upgrade! I'll be keeping my eye on this one for sure since I just acquired a pair of JK D44s and I'm thinking about doing a 4-link / 3 link combo.
Also, great score on those axles Those Waggy 44s are considered the "true" D44 in strength and they already come equipped with the right gearing and spools
BTW - very clean and nice looking XJ 2D!
Founder of
B2CARPEN is offline
post #3 of 379 Old 05-31-2011, 06:02 PM Thread Starter
2doorxj
2doorxj's Avatar
Thanks man! It should be a fun build. Once im done with this whole ordeal, ill probably do a 4 link rear.
As far as strength goes, they should be very well off with a some aftermarket shafts, and 35s.
If you dont mind me asking what did you pay for the JK 44s?
2doorxj is offline
post #4 of 379 Old 06-01-2011, 09:42 AM
B2CARPEN
The rear JK D44 is basically brand new w/ 800 miles from a JK unlimited so it's only 30 spline w/ open carrier, but is complete caliper to caliper and in awesome shape. I picked up the rear a couple weeks ago and paid $300
The front JK D44 is still TBD, I'm just waiting for the call to go and pick it up. If I had to guess I would say it will be priced a little higher around $500 or so since it's 32 spline and has a locker.
From what I've seen, these axles go for a hell of a lot more then what I'm paying for but since the guy is in a hurry to get rid of them to complete his rock jock D60 upgrade the price was amazing. I think a standard rear JK D44 (non-rubi) sells for $700 / $800 depending on the condition and the front JK D44s sell for over $1,000
As far as strength goes for your axles, I wouldn't even worry about upgrading the shafts if they are 30 spline. Should be plenty strong enough to handle 35s w/ some moderate wheeling. Now if you do extreme wheeling then yes upgrade w/ some chromos. And if you plan on doing a 4 link rear would you consider doing a double triangular 4-link? I'm still trying to decide what I want to do, if I do anything at all.
Founder of
B2CARPEN is offline
post #5 of 379 Old 06-01-2011, 02:16 PM
xGArfx
Whats the spline count on the outer stubs? I thought that was one of the only issues with waggy front axles besides being low pinion. I was told once by a wise man that the outter stubs are smaller then a 30 but it could of just been rumor. If so, upgrade the outers, new 760s and snap rings and be doneee. Sell those mini spools and get lunchboxes.
xGArfx is offline
post #6 of 379 Old 06-01-2011, 06:47 PM
BeepBeepGoJeep
1994 XJ Cherokee
Im pondering trying to do the same thing and get some JK 44s front and back instead of building another HP30 and xj44 for when i go 35s just incase one day i want 37s or something, i would possibly try to get the t-case from it also.
[]IIIII[]
BeepBeepGoJeep is offline
post #7 of 379 Old 06-01-2011, 10:15 PM Thread Starter
2doorxj
2doorxj's Avatar
Spools are gonna be a *****. Powertrax/aussies are in the works.
http://cgi.ebay.com/ebaymotors/80-92...-/250394476344
And ill get some 760 and full circle snap rings, one of my buds just did that on his 30, you probably woulddnt know him
2doorxj is offline
post #8 of 379 Old 06-01-2011, 10:17 PM Thread Starter
2doorxj
2doorxj's Avatar
Holy deal!!! I would have picked those up in a heartbeat!
If i was to go links in the rear (longgggg down the road)\
Id want to double triangulate to get rid of the track bar.
2doorxj is offline
post #9 of 379 Old 06-01-2011, 11:11 PM
DualPurposeXJ
1994 XJ Cherokee
You don't need a double triangulated 4 link to get rid of the track bar
DualPurposeXJ is offline
post #10 of 379 Old 06-02-2011, 07:43 AM Thread Starter
2doorxj
2doorxj's Avatar
Looks like i still need to do my homework on the rear. Luckily, ive done plenty on the front
2doorxj is offline
post #11 of 379 Old 06-02-2011, 09:01 AM
B2CARPEN
A single 4 link should be able to provide enough support to eliminate the trackbar but a double triangular would give you even more support from side to side movement.
Founder of
B2CARPEN is offline
post #12 of 379 Old 06-02-2011, 09:08 AM
justanotherjpr
Looks good. Check out RCV shafts instead of aftermarket UJ shafts for the front. A little more money but an unbeatable warranty and way stronger than a 760x.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #13 of 379 Old 06-02-2011, 08:04 PM Thread Starter
2doorxj
2doorxj's Avatar
Welded up my barnes 4x4 link tower today.
I think i have some pretty welds
Yes, i did fix the weld all the way to the right.
2doorxj is offline
post #14 of 379 Old 06-02-2011, 08:07 PM Thread Starter
2doorxj
2doorxj's Avatar
2doorxj is offline
post #15 of 379 Old 06-02-2011, 08:08 PM
BeepBeepGoJeep
1994 XJ Cherokee
Paints dripping lol.
[]IIIII[]
Need help with custom 4 link rear b_wern XJ Cherokee Technical Forum 5 01-24-2010 11:57 AM
Custom Waggy taillights. Let me know what you think skyjacked94xj XJ Cherokee Technical Forum 35 03-10-2008 08:02 PM
Waggy Axle Swap Brake Problem godplayer XJ Cherokee Technical Forum 5 05-16-2007 05:41 PM
Rear Grand Waggy 44's good swap? Cox89XJ XJ Cherokee Technical Forum 1 04-03-2006 07:13 PM
Custom Suspension Link Tech mississippi_xj XJ Cherokee Technical Forum 1 07-15-2004 03:34 PM
