-   -   Custom 3 link and Waggy 44 swap into my XJ (http://www.jeepforum.com/forum/f11/custom-3-link-waggy-44-swap-into-my-xj-1221450/)
2doorxj 05-31-2011 05:47 PM
Found some wagoneer 44s on craigslist, they were out of an '89, but they had been swapped into a YJ. The front has warn lockouts, 4.88 gears, and a mini spool. The rear has 4.88s and a mini spool. I paid 800 for the two of them. Oh yea, the guy threw in a 3/8s hd dif cover too :D
Here are the axles when i first picked them up:
http://i670.photobucket.com/albums/v...527_162920.jpg
Gears:
http://i670.photobucket.com/albums/v...529_134520.jpg
Okay, so here are my plans.
For the upper link ill be using:
-7/8s ruff stuff heims
-1.5 inch ID .25 wall DOM, probably going to be sleeved, i need to do more research.
Lower links
-(2) 1 1/4 ruff stuff heims
-(2) ballistic fab poly bushings
-1.5 ID .25 wall DOM, possibly going to be sleeved with 2 inch ID DOM, not sure on the width yet. I still need to do a little more research.
Axle Bracketry
- Ballistic Fab Coil buckets, with LCA mounts, and shock mounts. http://www.ballisticfabrication.com/Link-bracket-coil-spring-shock-mount-combo_p_1461.html
- Im going to be re-using a trackbar mount that i have, and most likely the trackbar itself too.
-Barnes 4wd, adjustable link tower. http://www.barnes4wd.com/product_info.php?products_id=2400
"Frame" Bracketry
- Ballistic Fab link mount http://www.ballisticfabrication.com/Heavy-Duty-Frame-Link-Mount_p_1511.html
- Ballisitc Fab upper/lower link bracket http://www.ballisticfabrication.com/Dual-frame-link-mount_p_1164.html
They will both be welded to HD offroad engineering Frame stiffeners.
Steering
-JCR OTK knuckle steering, and eventually chevy flat-tops and true high steer.
Im planning on a ~26' lower and a ~31 inch upper, Should keep the pinion pointed at the output on the t-case even at full droop. Around 8 inches of vertical seperation at the axle, and around 3-4 at the frame.
For all of the welding, ill be using my Marquette 220v with 75/25 gas, and .030 wire.
Practice welds:
http://i670.photobucket.com/albums/v...gx92/weld3.jpg
I have all of my "junk" on order, i hope to start fabricating by this weekend.
The only progress i have on the axles, is that they are both stripped of their old YJ SOA brackets, they still need to be ground down to bare metal though.
Grinding/ cutting sucks in this weather, all the sparks stick right to my sweaty skin.
http://i670.photobucket.com/albums/v...531_192533.jpg
I guess ill throw in a before shot of my XJ, once im done, its gonna have 35 inch MTR/kevlar, and soft 8s (the official rim of jeepforum)
http://i670.photobucket.com/albums/v...511_191301.jpg
All comments, questions, criticism, concerns are welcome:wave:
B2CARPEN 05-31-2011 05:52 PM
Sounds like an excellent start for a nice axle upgrade! I'll be keeping my eye on this one for sure since I just acquired a pair of JK D44s and I'm thinking about doing a 4-link / 3 link combo.
Also, great score on those axles :highfive: Those Waggy 44s are considered the "true" D44 in strength and they already come equipped with the right gearing and spools :drool:
BTW - very clean and nice looking XJ 2D!
2doorxj 05-31-2011 06:02 PM
Thanks man! It should be a fun build. Once im done with this whole ordeal, ill probably do a 4 link rear.:wolverine:
As far as strength goes, they should be very well off with a some aftermarket shafts, and 35s.
If you dont mind me asking what did you pay for the JK 44s?
B2CARPEN 06-01-2011 09:42 AM
The rear JK D44 is basically brand new w/ 800 miles from a JK unlimited so it's only 30 spline w/ open carrier, but is complete caliper to caliper and in awesome shape. I picked up the rear a couple weeks ago and paid $300
The front JK D44 is still TBD, I'm just waiting for the call to go and pick it up. If I had to guess I would say it will be priced a little higher around $500 or so since it's 32 spline and has a locker.
From what I've seen, these axles go for a hell of a lot more then what I'm paying for but since the guy is in a hurry to get rid of them to complete his rock jock D60 upgrade the price was amazing. I think a standard rear JK D44 (non-rubi) sells for $700 / $800 depending on the condition and the front JK D44s sell for over $1,000 :2thumbsup:
As far as strength goes for your axles, I wouldn't even worry about upgrading the shafts if they are 30 spline. Should be plenty strong enough to handle 35s w/ some moderate wheeling. Now if you do extreme wheeling then yes upgrade w/ some chromos. And if you plan on doing a 4 link rear would you consider doing a double triangular 4-link? I'm still trying to decide what I want to do, if I do anything at all.
xGArfx 06-01-2011 02:16 PM
Whats the spline count on the outer stubs? I thought that was one of the only issues with waggy front axles besides being low pinion. I was told once by a wise man that the outter stubs are smaller then a 30 but it could of just been rumor. If so, upgrade the outers, new 760s and snap rings and be doneee. Sell those mini spools and get lunchboxes.
BeepBeepGoJeep 06-01-2011 06:47 PM
Im pondering trying to do the same thing and get some JK 44s front and back instead of building another HP30 and xj44 for when i go 35s just incase one day i want 37s or something, i would possibly try to get the t-case from it also.
2doorxj 06-01-2011 10:15 PM
Spools are gonna be a *****. Powertrax/aussies are in the works.
http://cgi.ebay.com/ebaymotors/80-92...-/250394476344
And ill get some 760 and full circle snap rings, one of my buds just did that on his 30, you probably woulddnt know him;)
2doorxj 06-01-2011 10:17 PM
Holy deal!!! I would have picked those up in a heartbeat!
If i was to go links in the rear (longgggg down the road)\
Id want to double triangulate to get rid of the track bar.
DualPurposeXJ 06-01-2011 11:11 PM
You don't need a double triangulated 4 link to get rid of the track bar
2doorxj 06-02-2011 07:43 AM
Looks like i still need to do my homework on the rear. Luckily, ive done plenty on the front:D
B2CARPEN 06-02-2011 09:01 AM
A single 4 link should be able to provide enough support to eliminate the trackbar but a double triangular would give you even more support from side to side movement.
justanotherjpr 06-02-2011 09:08 AM
Looks good. Check out RCV shafts instead of aftermarket UJ shafts for the front. A little more money but an unbeatable warranty and way stronger than a 760x.
2doorxj 06-02-2011 08:04 PM
http://i670.photobucket.com/albums/v...602_153153.jpg
Welded up my barnes 4x4 link tower today.
I think i have some pretty welds:)
Yes, i did fix the weld all the way to the right.
2doorxj 06-02-2011 08:07 PM
http://i670.photobucket.com/albums/v...602_220337.jpg
BeepBeepGoJeep 06-02-2011 08:08 PM
Paints dripping lol.
The time now is 02:08 AM.
