Quantcast Currie Tie Rod Up Grade...Yes or No??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Currie Tie Rod Up Grade...Yes or No???
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 04-03-2007, 10:46 PM   #1
forgottenwave
Three Part Question:
1. I was going to upgrade my stock Tie Rod System to the one that Currie makes. I am gearing my jeep towards flat out speed and launching it maybe here or there. Is this a good product or is there equal with less of a price tag out there???
2. I need a longer drop pitman arm to level things out a bit better so if I got the Currie upgrade would I still need the pitman arm or would I be able to get a better angle because this product is a little longer when adjusted over the stock ones...
3. Any cheap suggestions to a drop pitman arm for a 3 and a bit lift that can stand some good abuse???
Willie
forgottenwave is offline   Reply With Quote
Old 04-03-2007, 10:55 PM   #2
LEAD_NOT_FOLLOW
1989 XJ Cherokee
You should never need a drop pitman arm...
LEAD_NOT_FOLLOW is offline   Reply With Quote
Old 04-03-2007, 11:08 PM   #3
forgottenwave
Do you think there is some thing up with the front end that is causing my front wheels to be so far off center???
Old 04-03-2007, 11:21 PM   #4
kg4kzv
1995 XJ Cherokee
Give us some specs on your rig so we can help. please clarify off center side to side would be track bar. Front to back in wheel wells is the control arms. Toe in-toe out would be tie bar. Steering wheel off center could be drag link, track bar or combo of both. Thanks to stock inverted y steering linkage any lift or Suspension travel changes the toe settings.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline   Reply With Quote
Old 04-04-2007, 12:05 AM   #5
sjd78
Why is that? If you lift your jeep and dont have money to upgrade the steering then isnt it a cost effective way to lessen the drag link angle?
1998 Cherokee XJ
AW4,NP231 W/SYE & CV Drive Shaft
D30 W/Detroit, Alloy's & 4.88's, D44 W/Detroit, Alloy's & 4.88's
35" BFG M/T's On 15x8 Soft 8's
5.5" T&T/RE Long Arm Lift, T&T Frame Stiffeners, JKS Sway Bar Dico's, RE Monotube's, T&T Steering Box Reinforcement, and much more!
sjd78 is offline   Reply With Quote
Old 04-04-2007, 01:00 AM   #6
forgottenwave
Chris
Here is what it looks like in the front. Everyone says that I should undo the track bar shake the jeep to get the wheels to center and then re-attach. But the track bar is as far out as is safe to extend.
Old 04-04-2007, 01:07 AM   #7
sjd78
Hard to tell but it looks like your axle isnt centered under your jeep. You need to adjust the track bar out to get it centered.
1998 Cherokee XJ
Old 04-04-2007, 01:30 AM   #8
forgottenwave
It is out as far as I can go without it becoming sketchy.
Old 04-04-2007, 02:43 AM   #9
craminator66
Then get a longer adjustable track bar.
00' XJ (lift, tires, HP dana 30 4.10's, Aussie Locker in front)
craminator66 is offline   Reply With Quote
Old 04-04-2007, 03:09 AM   #10
EricsXJ
The Post man
EricsXJ's Avatar
It will lessen the angle of the drag link but it is not worth the problems it can cause (bumpsteer) as well as added stress to the steering box bolts / frame.
You can easily run around 6" of lift without the use of a DPA. Higher than that you should look into a high-steer setup in which case you still don't need a DPA. The only time I'd say a DPA is okay is if you are 6" or more and want to keep the stock steering (or Currie, which you asked about and is a good upgrade to stock) AND if you only use a ZJ pitman arm which is only about an inch of drop on an XJ.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 04-04-2007, 05:10 AM   #11
godplayer
What if you have a bumper that reinforces the steering box and you're doing an axle swap so you can position the trac bar bracket where ever you want? Is it ok to use a drop pitman arm then?
92 Jeep Cherokee 2Dr Sport - 3 inch BDS springs, 2 inch homebrew coil spacer, 1 inch homebrew block, 1.5" RE Boomerang Shackles, Rustys Upper and Lower Adjustable Control Arms, Rustys Adjustable Trac-bar w/ Frame Mount, Rear Waggy D44 w/ Lockright, Front Waggy D44 w/ Full Spool, 4.88 Yukon Gears, PORC SYE, 140lb Homebrew Rocker Panels, 33x13.5LT15 Pitbull Rockers on 15x10 Black Steelies.
96 Jeep Cherokee 4Dr Sport - Daily Driver
65 Jeep CJ5 - Project, Wanted Prelude seats
godplayer is offline   Reply With Quote
Old 04-04-2007, 08:03 AM   #12
forgottenwave
Who makes an adjustable track bar that is good strong quality that isn't going to break the bank???
Old 04-04-2007, 08:58 AM   #13
Voluster
I'm gonna replace my rustys trac bar with the TnT customs one. but they won't be back till april 9th.
I keep breaking the trac bar ends on the frame mount. plus I've stuffed it into the oil pan from jumping the thing.
Good luck
Nitrous is like a hot chick w/ an STD, you wanna hit it, but you'r afraid of the concequences
Voluster is offline   Reply With Quote
Old 04-04-2007, 09:33 AM   #14
kg4kzv
1995 XJ Cherokee
One thing no one has said yet is a steering upgrade will not get the axle centered either will a drop pitman arm your track bar is to short. I have a Rusty's TB it was great at first but now the soft rubber bushings are kina mushy and may be causing DW so now I will be getting a RE track bar and giving it a try. As Eric said we are hearing good things about the TNT track bar as well. Do not skimp on your Track bar get a good one. You will thank us later.
Chris
Old 04-04-2007, 01:25 PM   #15
forgottenwave
Chris
I know this may sound bad but who is RE and is it custom made or do they come at certain sizes depending on your lift??? Do you have a link to the company so I can take a peak??? I plan on running my baby hard like my last 3 Cherokees. I'm ready to sell every thing I have to make sure not to skimp on any part of this build. Most likely if it is stock it will be replaced!!!
How does the saying go: "Stab it and Steer!!!"
Glock Forum
