the cure for a sagging door? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > the cure for a sagging door?
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 07-14-2008, 11:33 PM   #1
blacky_j
anyone knows the cure to a sagging door? (driver door)
[IIIIII]
blacky_j is offline   Reply With Quote
Unread 07-14-2008, 11:38 PM   #2
powelljwp
1994 XJ Cherokee
look at the hinges see if the ar pulling off of the frame if so weld them back or take off the doors.
powelljwp is offline   Reply With Quote
Unread 07-15-2008, 12:32 AM   #3
joey-nac
1993 XJ Cherokee
take the doors off
1993 2 door XJ Sport 4.0
5" DPG Coils with 3/4" spacer
4.5" Rough Country Leafs with 1" TNT boomerang lift shackle.
TNT Longarms with Bellypan
TNT Frame Rail Stiffenerz
DPG Gas Tank Skid
D30 Aussie locked with Yukon chromollys shafts 4.88s
D44 33 spline detroit with Moser chromollys shafts 4.88s
Teraflex SYE with Tom Woods custom DS
36x13.50 Iroks on 15x10 Pro Comp Rock Crawlers with Custom beadlocks.
joey-nac is offline   Reply With Quote
Unread 07-15-2008, 04:40 AM   #4
XJ_Austria
1994 XJ Cherokee
how are you doorless guys dealing with rain?
94 Cherokee 4,0 HO 192 hp
6" RE Superflex, 33x10,5 on 7x15 Dotz Dakar 5mm offset,
TJM rear steel bumper, ConFerr 6" heavy duty Roof Rack, narrowed, 4x6 feet with 8 Hella ligths
JKS Quick-Disconnects, rear sway bar deleted
XJ_Austria is offline   Reply With Quote
Unread 07-15-2008, 06:19 AM   #5
dcorn
Putting the doors back on or parking it in the garage.
Just don't drive when its supposed to rain.
1998 Cherokee Classic - White - 5" lift - 35" tires - locked/geared/shafted/armored
2004 Grand Cherokee Overland - Stock DD
dcorn is offline   Reply With Quote
Unread 07-15-2008, 09:35 AM   #6
_Kyle_
Not sure how much this helps you, but the sagging door on my ZJ was caused by worn door pin bushings so I replaced all of that and solved the problem.
-Kyle
1996 Grand Cherokee
RIP Troy (bigbluezj94)
1996 ZJ FOR SALE
_Kyle_ is offline   Reply With Quote
