cranks but doesnt start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > cranks but doesnt start
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-23-2011, 10:45 PM   #1
Pfeifferj
Swapped out a 96 4.0 engine with a 87 amc 4.0, the factory wire harness from the 96 is being used and we are using the 96 distributor. Engine has spark, fuel, and compression but still doesnt start. Tried using starting fluid, the rotor points to the #1 cylinder on the cap while at TDC. Also tried discoing the crank sensor. Any suggestions?
'85 CJ-7 Renegade 304 swap/TF999/Dana 300, American Racing Baja 15x10, 33" Dueller MT's, Optima Battery, Smittybilt XRC-8, Cobra 19 Ultra III/ 4' Firestick/ 15w PA
"You dont need A/C in a Jeep, the f***ing doors come off!"
Pfeifferj is offline   Reply With Quote Quick reply to this message
Unread 11-24-2011, 12:01 AM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Using the 1996 flywheel/flex plate ?
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 11-24-2011, 12:01 AM   #3
Pfeifferj
Got the engine to start, ran rough at first then smoothed out at idle. The engine doesnt like to start by itself without the throttle being WO. it also doesnt rev above 1500rpms without backfiring and shaking. Id like to think it is a throttle body/fuel problem but i didnt thing it would backfire with a fuel problem. any suggestions?
Unread 11-24-2011, 12:02 AM   #4
Pfeifferj
Originally Posted by CJ7-Tim View Post
Using the 1996 flywheel ?
Yes we have the 96 flywheel on it
Unread 11-24-2011, 12:11 AM   #5
CJ7-Tim
CJ7-Tim's Avatar
Double check that the distributor is indexed correctly. Make sure the plug wires are on in the correct order. Test the fuel pressure. 96 is OBD-II it needs to run and drive for 10 minutes to establish ECM data tables for starting.
Unread 11-24-2011, 12:24 AM   #6
Pfeifferj
What do you mean by indexing? From what i can see the distributor cant be adv/retarded manually by turning the distributor. Ill double check the plugs and run it for 10 minutes. We've only had it running for about 3 minutes so far. Does that have anything to do with why it wont start by itself and only with WOT?
Unread 11-24-2011, 04:55 AM   #7
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Correct. The housing can't be turned but the shaft/rotor could be a tooth or two off when installed....Very common.
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2011, 09:09 AM   #8
Pfeifferj
Well got it running great now, it was a tooth off.
Unread 11-24-2011, 09:15 AM   #9
cruiser54
cruiser54's Avatar
1990 MJ Comanche
99% of the time when there's a starting problem on an engine swap, that's the cause. Glad to hear it's up and running.
Unread 11-24-2011, 09:29 AM   #10
MJHEMI
Hey I have had that same problem with a 4.0 swap. What u have is an engine that is 180 degrees out of timing. So the rotor is on number one just not on tdc compression. The 4.0 will run this albeit very poorly and will require wo throttle to start.
MJHEMI is offline   Reply With Quote Quick reply to this message
Unread 11-24-2011, 09:37 AM   #11
MJHEMI
To remedy this you must pull distributor and number one spark plug. Rotate engine with finger or cork over the spark plug hole. When your finger/cork is blown off by the compression stroke u are on tdc compression. At this point refer to the timing marks on the balancer, small forward or backward adjustment may be required to align marks. At this point reinstall distributor and enjoy.
