#46 | |
My starting woes
2001 XJ
I have a hard start issue, 5 seconds usually. If I turn off the ignition and then start right up, no problems, but the longer it sits, the longer I have to crank the next time...except for when it is cold and been sitting for more than a day, then it starts right away, no cranking. New fuel pump and injectors have been tested. I was told they were good. I also have that hesitation when going up hills. Is this a CPS problem?
#47 |
Looks like I will have to drop the transmission. Is that a major job or not too bad? I am off to buy a Chilton's or Haynes today. I found someone on the internet that said they have heated up a nail red hot and melted it into the sensor and then pryed it out that way. Might give that a shot. Any advice on the tranny drop?
#48 |
I have a similar problem, but a bit different. Mine will occasionally not start. Kind of random. I an hold the gas and it will start. If I let off it will die. It will be fine after a minute. Now it is doing this more often and I notice that it is idling rough when it does start. If this the CPS?
#49 |
Does anyone have a picture of where the wire plugs in at, from the top of the engine? I think I need to replace it, but can't find the plug to test it. I have a 2000, so it should come up on the passenger side, if I'm not mistaken.
#50 | |
Yes, yours comes up the passenger's side IIRC ![]() . ![]()
'99 XJ Sport MY BUILD Thank You Hooligan!!! XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA! |
#51 | |
exact same problem
#52 |
Where'd that bolt go...?
i would not trust a cps off ebay
1995 XJ Cherokee Sport 4.0L / AX-15 / NP231 / D30/C8.25 Firestone 235/75 Destination M/T Tires 251,500mi and runnin' strong -Justin- Write-ups: Shackle Relocation Brackets Durango Steering Box and ZJ Tie Rod Swap Extending the rear diff vent Cowl Snorkel Mod Non-Fuel/Spark-related / NO CRANK diagnostics Fuel Injector Swap Project Danger Cart - A super-powered, high-tech vehicle designed by a genius, or perhaps space aliens |
#53 |
Well, Autozone has one for $65 so I might pick that one up. At any rate, do you agree that the CPS may be the problem?
Thanks |
#54 | |
after i changed the tranny in my xj i forgot to bolt in the CPA( i just set it in there and forgot) it still ran until i went wheeling and when i shut it off i got no fire.. after thinking about it for a little while i finally figured out the problem. i used speaker wire( because of course the bolts were missing) to set it back in place to get it home. took me about ten minutes and forearm scolds.
95 xj,5 speed, 5" lift, 33 12.5 dessert dogs chrysler 8.25, "my xj is so horny, sometimes im scared itll came right up in a wheelie" |
#55 |
CPS - 95 Cherokee SE 2.5L 5-speed
Just some info for those who may have a similar engine to mine:
I encountered a similar problem to others on here - my 95 2.5L Cherokee 5-speed was running fine (I changed the cap, rotor, plugs, and wires a couple weeks ago). Then, one afternoon it suddenly would crank and just not turn over after running fine that morning. I was getting fuel, just no spark. After searching these threads, I decided to take a chance and replace the crankshaft position sensor before looking into other possible causes. Picked one up at Advanced for around $70. I don't own extensions, but I found I didn't need them. I have a mini-ratchet and, although it was a little tedious, I was able to remove the old one and install the new one from underneath the drivers side (no ramps, lift, etc). The bolts were 11mm. Best of all - IT WORKED! I love these forums. |
#56 |
glad you got it fixed
#57 |
If you unbolt the crossmember and lower the transmission with a jack it should get you a little more room to work in there.
Seeing this though makes me wish I would've replaced it when I did the clutch last week....
Jason '98 XJ: UpCountry, bastard pack, 2" spacers, JK shocks, 31" BFG AT's '81 Honda GL500 Colorado Jeep Club Member #399 |
#58 |
could this be the issue with my truck? someone told me it may be, yesterday well driving my jeep died , no spark.. The timming, distributor, started, fuel pump are all fine, it just wont start
#59 |
It could be, or it could be a bad Ignition Control Module and/or ignition coil (if it has a lot of miles on it). I replaced the CPS, distributor, ignition coil, plug wires, plugs, fuel pump, and fuel filter before replacing the ICM (some of those parts needed replacing anyways, like the plugs/wires/fuel pump). Only after I replaced the ICM did the stalling, dieseling, and backfiring go away.
'87 XJ 4 door 4.0L 4x4 420k+ miles - not enough mods '99 Firebird V6+4L60E w/BAR certified LS1+4L60E swap - as many mods as the Jeep |
#60 |
I would say it definitely could be. These and other jeep forums are rampant with tales of CPS failures. Mine didn't fail while driving (I just couldn't start it up). You may want to search around for other diagnostic procedures to eliminate other potential causes before jumping in, but I would guess it's definitely a possibility its the CPS.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
