Quantcast Crank Position Sensor Write Up - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Crank Position Sensor Write Up
Old 11-19-2005, 08:23 AM   #16
cj7guy
Anybody have a good write-up on advancing timing, or even know of a company that makes aftermarket CPS units that are already set to advance timing?
cj7guy is offline   Reply With Quote
Old 05-13-2006, 05:07 PM   #17
BigJpXJ
Great right up, for me. It was a 7/16 socket that fit the bolts for me. I have a 98 cherokee though.
And man, i wish i heeded to the advice to wait till the car is cooled off just a tad...it was kinda like when u bite into hot pizza and u dont know what to do with the burning piece in your mouth, except the burning is on your arm and u cant figure out how to get it out of that tiny space FAST!
[U]98 xj classic San Diego, CA[/U]
RE 5.5 LA
AA HD SYE
12.5x33 A/T
np231
BigJpXJ is offline   Reply With Quote
Old 05-15-2006, 09:31 AM   #18
borkap
Mine is sitting in the parking lot at work dead. I have a 97 4.0 with a manual transmission. Would that be in the same place? I just had mine replaced about a year ago.
Thanks in Advance.
borkap is offline   Reply With Quote
Old 05-15-2006, 11:18 AM   #19
TPI Monte SS
Great writeup! I'm tempted to buy one now for my '01, as it has been experiencing some loooooooong startup times in the AM. I have to crank it like 15-20 seconds sometimes before it fires up.
Steve Ragusa - North Jersey
'01 XJ - SOLD!
'06 Infiniti G35x - New DD. :)
'03 KJ Limited -WifesJeep- 3.7, Auto, NP 242, '06 Limited 17's. 40K miles.
TPI Monte SS is offline   Reply With Quote
Old 05-15-2006, 02:39 PM   #20
redyouch
to advance the timing you can just make the holes larger to move the CKS over a little. just not sure which way...
[SIZE=2][b]90 Cherokee Laredo[/b] destroyed
[b]93 Cherokee Sport[/b] destroyed
[b]88 Cherokee LTD[/b] junked
[b]98 Cherokee Classic[/b] totaled
[b]95 Cherokee Sport[/b] flipped
[b]87 Wrangler[/b] sold for a profit... :)[/SIZE]
redyouch is offline   Reply With Quote
Old 05-15-2006, 02:42 PM   #21
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Pretty sure Hesco makes one. I had read an online article years ago that mentions some advance on a stock "high altitude" version of the CPS. Not sure if this really exists, but might be worth looking into.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 08-01-2006, 09:51 PM   #22
artboy
take the top bolt OFF first and put it back ON last... this way there is no chance it might drop into the hole where the sensor goes into the bellhousing.
1993 XJ Sport RIP (Parts) - 189k, white, 4.0, automatic, command-trac NP231
1996 XJ Sport Daily Driver - 95k, stone white, 4.0, automatic, selec-trac NP242, Tow Hooks, SRB fog lights, tinted glass.
2005 Wrangler Rubicon Summer Toy - 8k, 100% STOCK...silver, automatic, soft and hard tops and doors
My Pics
"life moves pretty fast... if you don't stop and look around once and awhile, you could miss it"...F. Bueller
artboy is offline   Reply With Quote
Old 08-20-2006, 12:19 AM   #23
89cherokee4ever
1989 XJ Cherokee
Quick question
I just swapped in a rebuilt Renix in my 89 XJ... and even before the project I had a really tough time starting the darn thing! 219,000 miles... DUH! of course it would be hard to start! I got my new motor in and it's a little easier to start... but still very difficult! sometimes takes me around 8 secconds of cranking to start. I checked the timing and it's about 10-12 degrees retarded and the Jeep sputters 4 times, every time after I start it... hot or cold. I knew to check the knock sensor first of all... HUGE crack in it! So $54 later I got a new knock sensor... but nothing is different. Timing is still off 10-12 degrees and she still tries to die when first started in the mornings! I was just wondering if my problem(s) could be my... crispy CPS? Did I mention my gas mileage is terrible... I assume from the timing? est. mpg 13.5 in town... stock everything
89cherokee4ever is offline   Reply With Quote
Old 08-20-2006, 07:51 AM   #24
BB1
Thank's!, Very timely write-up I'm waiting for the new CPS to arrive 8/21. I can't believe that the dealer and every part's store in town did'nt have one in stock?.
I realize mine is a 92'(old) I'm more pissed that Chrysler could'nt keep them standard to cover a variety of year's?.
BB1 is offline   Reply With Quote
Old 08-20-2006, 10:34 AM   #25
AZ Jeff
That won't work on the OBD-II engines. They revert to base timing even if you relocate the CPS a few degrees.
That WILL work on OBD-I and Renix engines.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 02-27-2007, 06:41 PM   #26
RickyN29
Omg, I was so afraid of doing this (well, not afraid, but it looked hard to get to).
From start to finish, first time doing it, it took me 20 min.
I am about to go out and snap a picture of my extension setup which worked like a CHARM.
No string, no extra hands, just extensions, socket and 20 min.
Brb
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline   Reply With Quote
Old 04-05-2007, 05:59 PM   #27
Gez
Firstly hi to all, New member here.
I have a 94 Cherokee (4.0) dead in my drive at the moment, I have relayed the symptoms to my local dealer and he say's it's the crank position sensor. Thing is that when I turn the ignition on I no longer hear the fuel pump prime, and there is no fuel pressure in the fuel rail. Does the CPS also control the fuel pump?
Thanks in advance for any replys.
Update- Just run some further tests, I have proper spark but no fuel pressure, fuel pump prob.
Gez is offline   Reply With Quote
Old 04-05-2007, 06:43 PM   #28
87bucket
i replaced mine last year. i used a spiffy coil extension, that i recently cut the end off of to use as an HD drain snake. if mine fails again, im cutting a hole with a holesaw in the firewall right behind those bolts, then using a rubber floor plug (ala cj) to plug the hole. same plan for my top 2 bellhousing bolts when i do the clutch later this summer.
94 4-door, 4.0, AX-15, NP231, Chryco 8 1/4, 2" BB, 30x9.5 Kumho MT's
87bucket is offline   Reply With Quote
Old 04-06-2007, 07:22 AM   #29
tvguy1971
very nice write up. i changed mine on our 1990 last summer. it was my first time changing one so it did take longer then 20minutes but i took my time. and ya! be carefull not to drop anything in the bellhousing!! using a ujoint adapter (whatever there called) and some long extensions works best. not sure on the size, 11 - 12mm or 7/16 was one of em.
tvguy1971 is offline   Reply With Quote
Old 04-09-2007, 11:08 PM   #30
RickyN29
Opps! I guess I never got around to posting the pictures. Here was my setup that worked beautifully!
*Rusty's ~6" Lift
Glock Forum
