Crank position sensor problems (maybe) - Page 3 - JeepForum.com
post #31 of 37 Old 04-05-2014, 02:40 PM
drs01xj
Same problem, cranks but no start
This is starting to drive me crazy! About a week and a half ago I tried to start my truck. It fired and died. New cam position sensor, new crank position sensor, new coil, new ASD relay. NO SPARK! It wont even fire on starting fluid.
drs01xj is offline
post #32 of 37 Old 04-05-2014, 04:08 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Thanks for your post.
We’re here to help but you must understand that all Jeeps are not the same.
In order for us to give you more accurate advice and help, we must know the following, as applicable, along with detailed information as to the symptoms/problems etc:
Year
Model
Engine
Transmission
Transfer case
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is online now
post #33 of 37 Old 04-06-2014, 08:02 AM
drs01xj
Sorry about that. It's a 2001 Cherokee Sport. 4wd, 4.0 engine, automatic transmission.
drs01xj is offline
post #34 of 37 Old 08-11-2014, 01:51 PM
skeletonizer
Will you still get spark if the CPS is causing a no start?
I have a '94 zj 4.0 auto. It appears I have spark, fuel, and compression. It fired but failed to start and now just cranks...
Thanks in advance.
skeletonizer is offline
post #35 of 37 Old 08-25-2016, 09:23 AM
AVjeeper1
1989 XJ Cherokee
This is an awesome thread. Thanks for the information so far. I think I am experiencing "Thermal Failure." Same no start symptoms as listed in previous posts. If i disconnect the CPS connector and cycle the key several times and then reconnect the CPS connector it will most often start up again. My connectors look old and worn. Anyone know where I can get CPS pigtails? Does splicing interrupt the current or adversely affect input signals, etc...?
Much obliged,
AVjeeper1
Jason
AVjeeper1 is offline
post #36 of 37 Old 08-25-2016, 10:31 AM
jordan96xj
jordan96xj's Avatar
If the splicing is done properly, it will not cause any problems. FSM procedure for splicing calls for stripping 1/4-1/2 inch stripping of insulation from each wire end. Heat shrink is slid down one wire. The strands of the wire are then pushed together (as in intermingled, not twisted together, not using twist caps, etc.). The intertwined strands are then soldered. The idea is to have as many strands touching as many other strands as possible. Then the heat shrink is pulled over and applied to protect. I think they recommend at least 1-2 inches of heat shrink on either side of the splice to be sure that moisture won't get in later.
Things I keep around that help fix Jeeps:
AeroKroil and Fluid Film
BAFX Products 34t5 Bluetooth OBDII Scan Tool and Torque Pro OBD2 App for Android
Etekcity MSR-P600 Digital Multimeter
Bernzomatic TS4000 Trigger Start Torch + MAP Gas
1/2 inch sockets, Breaker, Cheater Pipe, and BFH
jordan96xj is offline
post #37 of 37 Old 08-25-2016, 07:00 PM
tax2dth
I have a 99 jeep Cherokee 4.0. I was driving stopped at Red light engine died and won't start back. I done some research and everything pointed at the crank position sensor so I replaced it still won't start. I am getting fire at the plug, I'm getting fuel, no blown fuses, no engine codes. When I crank it if I hold gas to floor it will back fire through the intake. Before this all happened I did have symptoms of cps going out rough idle sometimes when I started it the fuel gauge would work for few min then start working. So what do I need to test next any help be appreciated.
Sent from my SM-G925P using Tapatalk
tax2dth is offline
cps , crankshaft position , sensor
Crank Position Sensor 96cheron XJ Cherokee Technical Forum 12 03-16-2011 03:40 PM
Crank position sensor 97jeepgcl XJ Cherokee Technical Forum 6 12-19-2009 11:34 AM
crank position sensor dancinbills XJ Cherokee Technical Forum 1 11-05-2009 05:57 AM
Crank Position Sensor, Which One? DesertOne XJ Cherokee Technical Forum 9 03-29-2009 09:04 PM
XJ Crank position sensor....help me please craigincali XJ Cherokee Technical Forum 2 05-18-2007 10:09 PM
