Quantcast Crank position sensor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Crank position sensor
Old 12-18-2009, 07:40 AM   #1
97jeepgcl
Should I have removed the paper off the new sensor?, the directions said not to, but after replacing the engine still has no spark, but the old sensor that I had tested indicated faulty and I am wondering if I need to remove the new one and remove the paper.
Thanks all,
Jeff
97jeepgcl is offline   Reply With Quote
Old 12-18-2009, 08:48 AM   #2
Mikeand
I would think so, hows the sensor going to work if theres something blocking it?
1996 Cherokee Sport -4.6L Stroker, TB Spacer, Cold Air Intake, APN Header - D30 front / 8.25 Rear -RC 3" Lift -Dakota Leaf Pack -Rough Country Discos / -31" General Grabber A/T2s on 15x8 Cragar Soft 8s -Diamond plate rear quarter panels -Front bumper with hoop - IRO Double shear Track Bar and HD tie rod -Homemade light bar
Mikeand is offline   Reply With Quote
Old 12-18-2009, 09:33 AM   #3
tjwalker
It's the crank sensor!
tjwalker's Avatar
Post the directions exactly as they were written.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 12-18-2009, 09:58 AM   #4
97jeepgcl
Directions are as follows:
Do not remove paper on sensor tip. The paper spacer is about .030 inch thick pasted on the of the sensor probe. should not remove prior to installation. it provides the required air gap between the sensor and engine moving parts. After installation and the engine is started, it gets sheared off.
My question is how do I know it is touching enough to shear off the paper? and if it does'nt then it won't start...right?
Thanks
Old 12-18-2009, 02:00 PM   #5
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
You did not post your Cherokee information. The correct answers to even the most simple questions will vary significantly based on your model year, engine size, transmission, and transfer case. ALWAYS include this info in your tech questions.
There are three type of Crankshaft position Sensor Mounting styles. You need to be sure the replacement CPS is the correct style for your year of XJ.
A) 2 Bolts
B) 2 Nuts
C) 1 Bolt
The paper spacer is for the 1 bolt style. The 1 bolt style is for older XJ's. Press the CPS firmly into the hole to make contact. If you have an older XJ that uses the one bolt style CPS, follow the instructions.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 12-18-2009, 02:09 PM   #6
Dunc
Click here Read this thread and then ask yourself "should I follow directions?" You can stop reading after the 1st and 2nd posts lol
Dunc is offline   Reply With Quote
Old 12-19-2009, 12:34 PM   #7
97jeepgcl
So are you insinuating that I am an idiot?, real nice comment there bud, you don't know me, did your mommy not ever tell you if you don't have anything nice to say then......well you being so smart can figure the rest out.
1997 Grand cherokee limited
4.0L
Glock Forum
