crank position sensor - JeepForum.com
post #1 of 2 Old 11-04-2009, 08:34 PM Thread Starter
dancinbills
1993 FSJ Cherokee
4litre 93 jeep cherokee country automatic. I have been looking for a cps and every where I look there seems to be a difference in price and what year and model but they look identicle even at the plug in . Is there a difference or can I use any one that looks identical. See one place it will say it fits this and another will say something different.
dancinbills is offline
post #2 of 2 Old 11-05-2009, 05:57 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I wouldn't go by "looks".
I have worked on quite a few xj's and by far have had the best luck with purchasing replacement crank sensors directly from Jeep. Quality control/reliability/longevity is higher than many of the aftermarket ones, which are very hit and miss.
Buy it from Jeep and you'll know you're getting the right sensor to mate with your vehicle.
If you do purchase aftermarket, getting the correct sensor should not be a problem for a partsman that knows their stuff. It is basic application data.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
New Crank Position Sensor bad? Lone Star XJ XJ Cherokee Technical Forum 12 07-14-2012 03:53 PM
Crank position sensor 97jeepgcl XJ Cherokee Technical Forum 6 12-19-2009 11:34 AM
Crank Position Sensor jeep12827 XJ Cherokee Technical Forum 0 07-06-2008 09:48 PM
CPS Crank Position Sensor JBACA XJ Cherokee Technical Forum 4 07-08-2005 06:22 PM
Crank Position Sensor Gil XJ Cherokee Technical Forum 5 08-30-2002 06:24 AM
