Quantcast Crank Position Sensor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Crank Position Sensor
Old 10-13-2008, 07:40 PM   #1
96cheron
I have a problem and ty for the replies in (4.0 Fuel problem) which leads me to the crankshaft position sensor .. It seems almost impossible to take it off without taking half the engine apart on my inline 6... can anyone tell me how to get it off... I dont want to take my engine apart just to take 2 bolts of to get the sensor off. I have read various Threads here and alot of starting problems lead to the cps. and i am thinking that is whats wrong with mine cause it will crank but it just wont turn over.
96cheron is offline   Reply With Quote
Old 10-13-2008, 07:40 PM   #2
BrunoS
go from underneath. use extension sockets. there are quite a few how to do it posts on this forum.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Old 10-13-2008, 08:00 PM   #3
96cheron
yea from underneath seems like the easiest route ... its just hard to see what i am doing, guess i will rely on feeling what i am doing
Old 10-15-2008, 09:50 AM   #4
ernesttbass35
Stop right there!!!!!!
BEFORE YOU EVEN DO THAT, TRY THIS... Unhook your battery, unplug the PCM (computer), take CPM out, take out 1 of the torx head screws on the outside of PCM (1/2 inch long), cut it in half and replace it, then do the other one. Now replace the CPM, hook it back up and hook up the battery. You will probably be all set now. Good Luck, Ernie
ernesttbass35 is offline   Reply With Quote
Old 03-15-2011, 03:38 PM   #5
dangerdakota
where is the cps.. my jeep 4.0l died well driving today.. no spark it crank and cranks and nothing happens. Its got fuel, the timming chain is fine, the distributor is fine, the starter is good.. just no spark// could this be the issue and how hard is it to replace
dangerdakota is offline   Reply With Quote
Old 03-15-2011, 03:49 PM   #6
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
CPS Install instructions -> http://www.jeepforum.com/forum/f11/crank-position-sensor-write-up-197260/
Test the CPS.
CPS Testing
Crankshaft Position Sensor Connector (CPS/CKP)
TESTING PROCEDURE 1991 – 2001 4.0L H.O. engines
1. Near the rear of intake manifold, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter across terminals B and C (See Image). Ohmmeter should be set to 1K-to-1OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
TESTING PROCECURE for 1987 – 1990 4.0 L engines
Test # 1 - Get a volt/ohm meter and set it to read 0 - 500 ohms. Unplug the CPS and measure across the CPS connector's A & B leads. Your meter should show a CPS resistance of between 125 – 275 Ohms. . If the CPS is out of that range by much, replace it.
Test # 2 - You'll need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. (The engine can't fire up without the CPS connected but watch for moving parts just the same!) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5vac, replace it.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 03-15-2011, 07:34 PM   #7
crosschecker
1995 XJ Cherokee
I found that lowering the back end of the tranny down gives you a fair amount of room to work and almost makes it decent to make the change.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline   Reply With Quote
Old 03-15-2011, 10:44 PM   #8
dangerdakota
how do you know if this is whats gone on my jeep.. It just lost spark in all 6 cylinders.. the trouble codes said lost control of all 6 injectors... does that sound like this could be the issue
Old 03-16-2011, 05:51 AM   #9
tjwalker
It's the crank sensor!
tjwalker's Avatar
Follow testing procedures noted by Tim earlier in this post.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 03-16-2011, 06:39 AM   #10
AmbuGrl
AmbuGrl's Avatar
lay with your body going from the drivers side of the jeep towards the passenger side. Get up close to the front tire and look up at about 1 o'clock angle. You can see the cps and the two bolts. I ran my new one down along the old one so when I took out the bolts, slid out the old, put in the new one and rebolted it all within a few minutes. (I found it easiest to lay on my left side and was able to do most of the work with one hand)
- HM1(SW/AW) USN 1992 to present
I drive an XJ, and all of my power windows work :)
DD (Mine) - 98 XJ Moss Green
(His) - 92 YJ
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline   Reply With Quote
Old 03-16-2011, 02:33 PM   #11
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Originally Posted by crosschecker View Post
I found that lowering the back end of the tranny down gives you a fair amount of room to work......
Too much work, just take the front drive shaft off the T-case.
I prefer to use all the ratchet wrench extensions in my tool box.
PM me for details
Old 03-16-2011, 04:36 PM   #12
fourlow
1994 XJ Cherokee
Ive never used an Ohmmeter before, i suspect my CPS is bad and would like to test it before I buy a new one.
That being said i just picked up one that came with my code reader. The code reader said it couldnt connect which worries me that it may be the ECM.
The range goes from 200-20m. It was stated to test in the range of 10k but i dont see that number, only 2000 and 20k are the ones closest to the range specified. Which range should I use? And which terminals should i plug into?
Ive tested the following and have these results
20m = 0
200k= 0
20k= 0
2000= 001
200= 00.4
This is the model I have
http://www.google.com/products/catalog?hl=en&client=firefox-a&hs=ftJ&rls=org.mozilla:en-USfficial&q=iequus+multimeter+3300&bav=on.2,or.r _gc.r_pw.&um=1&ie=UTF-8&cid=6106001888566369250&sa=X&ei=Ky2BTdTRMoS6sQOJ quXzAQ&ved=0CCwQ8wIwAg#
Current setup:
94 Xj 110,000 miles
Rustys Air Tube
JeepersandCreepers Bored out TB
GDI 3 core radiator
Flowkooler Water Pump
Suspension:
RE 3.5" (actual about 4 inches) 6030 SUPER-FLEX, RE1600 Adjustable Track Bar
Wheels/Tires:
Rock Crawler 152 Series, 3.75 Backspacing
31inch BFG MT's
fourlow is offline   Reply With Quote
Old 03-16-2011, 04:40 PM   #13
spdcat01TJ
spdcat01TJ's Avatar
This is how I did it. It can be a pain, but not really all that bad with long extensions.
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
NRA Member
'01 TJ Sahara, 3" BB front, 2.25" BB rear, 1.25 JKS BL, 1" MML, Skyjacker Hydro shocks,33/12.50x15 BFG TA/KO All Terrains homemade disco's, Hi-Lift, CB, GPS
spdcat01TJ is offline   Reply With Quote
Glock Forum
