#1 | ||
crank position sensor?
#2 |
I know when mine went out, it would randomly just not start. It would crank but not fire.
Then it would start right up after you left it for a while. Have you tried seafoam in the gas tank, that sometimes makes the engine run a little smoother, and its a hell of a lot cheaper than a CPS, it wouldnt hurt
2002 GMC 2500HD 8.1L - Tow Rig 1998 Jeep Cherokee - Wheelin Rig 1988 Jeep Wrangler - In progress... |
#3 |
The crank sensor is not your problem. Once the engine is running, the ECU doesn't use it. Before you buy any more parts, check the basics- gummed up throttle body, vacuum leaks, bad dist. cap/rotor, spark plug wires, etc. Any trouble codes?
#4 | |
#5 | |
#6 | |
locked and loaded
. For Sale - http://tinyurl.com/Tan-Overhead-Console . SUV's get groceries, Jeep's get dirty.
#7 | |
why would the cps only be used when starting but not running? Im confused on this point also. how else does the ecu know what position the crank is in (my 2000 has no distributer). anyway when my CPS went it simply wouldnt start period. and I got "NO BUS" in the odometer. I think my gauges were dead too. this is a 2000.
[COLOR="DarkRed"]2000 Cherokee Sport 4.0L Selec Trac[/COLOR] - mine - for occasional wheeling [COLOR="DarkGreen"]2007 Patriot 2.4L FD I 4x4[/COLOR] - wifes - doomed to rarely leave the street |
#8 | |
#9 | |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Crank position sensor | 97jeepgcl | Cherokee Technical Forum | 6 | 12-19-2009 11:34 AM |
| New Crank Position Sensor bad? | Lone Star XJ | Cherokee Technical Forum | 10 | 05-28-2009 08:39 PM |
| Crank Position Sensor | jeep12827 | Cherokee Technical Forum | 0 | 07-06-2008 09:48 PM |
| CPS Crank Position Sensor | JBACA | Cherokee Technical Forum | 4 | 07-08-2005 06:22 PM |
| Crank Position Sensor | Gil | Cherokee Technical Forum | 5 | 08-30-2002 06:24 AM |
The time now is 07:28 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
