Cracked header causing hesitation/rough idle? - JeepForum.com
post #1 of 3 Old 04-16-2005, 07:17 PM Thread Starter
JoeHo
Hey everybody. Lately my engine has been hesitating a bit, especially on the freeway, and it idles a little rough. This is the same thing that happened when my O2 sensor went bad a while ago, except no CEL. I know I have a crack in my header in the typical spot, but could this actually be causing my problem? If it couldn't, I know there's about a thousand other things that could be the problem, so I'm hoping that's it, and that the solution is an excuse to buy a banks . Any help is much appreciated.
AIM: xMoNsTeRLoBsTeRx
2001 XJ - commuter for a while
JoeHo is offline
post #2 of 3 Old 04-17-2005, 01:07 AM Thread Starter
JoeHo
Bumpity bump
JoeHo is offline
post #3 of 3 Old 04-17-2005, 01:12 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Try to pull trouble codes. A cracked header will cause a loss in performance though.
Derpy Hooves for President in 2012
Matt Gertsch is offline
Rough Idle, Bogging and Hesitation. anthonyg XJ Cherokee Technical Forum 2 06-23-2009 12:39 PM
Hesitation, backfire, rough idle?? khurley XJ Cherokee Technical Forum 9 05-23-2009 02:21 PM
Hesitation, backfiring, and rough idle (O2?) JoeHo XJ Cherokee Technical Forum 0 11-15-2007 10:37 AM
Rough Idle when cold and hesitation yoandkids XJ Cherokee Technical Forum 4 05-21-2005 08:54 PM
A/C Causing Rough Idling?? EEP Grl XJ Cherokee Technical Forum 5 04-23-2004 03:55 PM
