cracked exhaust manifold. - JeepForum.com
post #1 of 7 Old 04-17-2013, 07:57 AM Thread Starter
mayeni
1992 XJ Cherokee
My stock exhaust manifold is cracked right where the two pipes fuse into one, I can't see the hole crack since it is still on the car. The two parts is still close to each other. I have access to a 250 amp CO2 welder, and know how to use it, but I am unsure if it will just crack right next to the welding.
So should I weld it or should I buy a new stainless manifold? Since the new manifold should be shipped to Denmark it will be around 220$.
mayeni is offline
post #2 of 7 Old 04-17-2013, 08:44 AM
Timo_90xj
Timo_90xj's Avatar
If you MIG weld it, expect the manifold to crack fairly soon again.
***Under construction***
Timo_90xj is offline
post #3 of 7 Old 04-17-2013, 09:19 AM
habbyguy
Use the cracked manifold as an excuse to buy a header. It'll breathe better than the old stock cast iron manifold, plus it weighs less and looks cooler. I've been running an Ebay chrome header for over a year now. It was a nice, cheap mod that probably paid for itself in the first few thousand miles I drove (gas savings).
The design of the original manifold means it'll just crack again if you weld it up.
habbyguy is offline
post #4 of 7 Old 04-17-2013, 09:59 AM
buildin1XJ
I agree with not welding and replacing it. Also make certain the condition of your motor mounts and transmission mount as they can be a cause of manifolds cracking due to the design of the exhaust system.
buildin1XJ is offline
post #5 of 7 Old 04-17-2013, 10:31 AM Thread Starter
mayeni
1992 XJ Cherokee
I have brought a new one now. My motor mounts looks fine, I checked them very recent, but I don't know about my transmission mount. Would it be an idea to put a flex into the pipe downstream of the manifold.
It is something like this I have in my thoughts.
mayeni is offline
post #6 of 7 Old 04-17-2013, 10:43 AM
buildin1XJ
I have seen where people have done that. I have also seen somewhere an aftermarket exh man. that has something like that built into it.
post #7 of 7 Old 04-17-2013, 12:14 PM
Timo_90xj
Timo_90xj's Avatar
I put a 3" ID flex tube on my ZJ right after where downpipes from both cylinder banks join. No problems so far.
