CPS (crankshaft position sensor) - JeepForum.com
post #1 of 5 Old 08-15-2002, 06:10 PM Thread Starter
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
I'm just curious....
How many people have had this thing break and on what model year? What is the "newest" year you have heard of that had one fail?
Wondering if I should be worried about this in my 00'
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #2 of 5 Old 08-16-2002, 07:10 AM
BadXJ
I have an 89 XJ and I carrie 3 with me all the time... I hope you dont have the problems older XJ had... I havent had to replace one in about 2 years now.... I think your should be fine.. but you may want to carry one with you...
89 XJ black 2 door -6" Tomken suspension lift, 33X12.5 Mud Kings, 4:56 RPs, Dana 35 w/ Detroit locker, Dana 30 front w/ Detroit locker, transfer case tailshaft eliminator, custom off-road driveshafts, AW4 trans w/ cooler, Tomken front and rear bumper SEE PIC SEE PIC @
WIFE:
98 ZJ Limited, Loaded RED/BLACK
BadXJ is offline
post #3 of 5 Old 08-16-2002, 07:33 AM
bassicrob
bassicrob's Avatar
I have a '93 with about 76k miles and I had to replace mine 2 weeks after I was in a rollover. However, I am still getting the 11 code when I run the "check Engine Light" method diagnosis. Any clue? Last 50 cycles I presume or maybe still more probs?
bassicrob is offline
post #4 of 5 Old 08-16-2002, 07:40 AM
williak
On both my 87 (140,000)and 88 (120,000)XJ's, the CPS failed and I never noticed. They both ran just as well on the distributor pick up. Never had an engine light, nothing. Found out they had failed during my regular check ups.
williak is offline
post #5 of 5 Old 08-16-2002, 12:41 PM
jpcomanche
If your XJ's still ran, the CPS didn't fail. They might have been going bad, but they hadn't completely failed. If you don't believe me, go unplug your CPS and try to start your XJ. It will not run.
The CPS went out on my 90 MJ about a year and a half ago with about 90K miles.
1987 Wrangler
1990 Comanche Eliminator
2003 Wrangler Rubicon
jpcomanche is offline
Crankshaft position sensor or something else? ar275103 XJ Cherokee Technical Forum 2 07-21-2007 01:37 PM
Crankshaft Position Sensor falkan XJ Cherokee Technical Forum 8 08-26-2006 06:35 PM
crankshaft position sensor SpoonyGSR XJ Cherokee Technical Forum 7 04-16-2006 04:23 PM
Crankshaft Position Sensor on a '94 Catalina XJ Cherokee Technical Forum 2 06-02-2004 10:46 AM
Crankshaft Position Sensor guest XJ Cherokee Technical Forum 13 11-13-2003 07:32 PM
