Cps - JeepForum.com
post #1 of 13 Old 06-05-2007, 08:31 PM Thread Starter
Rollin
Cps
My friend has a 99 Cherokee sport 4.0l that will not start. it cranks and cranks but it wont start. It threw code 23 which is the crankshaft position sensor. So we went down to the autoparts store and $100 later we have a new crankshaft sensor in the jeep. Same problem. We cleared the codes in the ecu by unplugging the battery for 15 minutes but everytime the ignition is turned on, it throws the same code.
We checked the plugs and sure enough, no spark. There is fuel and the battery still has enough juice to turn the engine over, but there is no spark on any of the plugs. Does this mean the cap or rotor just coincidentally died at the same time as the CPS or could it mean that because the ECU isnt getting a signal from the CPS, it wont send a signal to the distributor to spark at the plugs? Is there anything that we could have missed?
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #2 of 13 Old 06-05-2007, 09:32 PM
curtjames37
curtjames37's Avatar
I would check the wiring to the CPS if you haven't already. What specifically did the code say?
curtjames37 is offline
post #3 of 13 Old 06-05-2007, 09:39 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
I agree check the CPS wiring to see if it burned on the exhaust.
If that appears fine I know my 1990 has a ignition control module under the coil that should control the coils spark. The coil pops into it with prongs maybe theres a bad connection there.
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
post #4 of 13 Old 06-05-2007, 09:41 PM
curtjames37
I think the ignition control module on the 99 is in the PCM. I know it is not right there with the coil. Someone correct me if I'm wrong.
post #5 of 13 Old 06-05-2007, 10:17 PM
jv3kxj
It is possible that he got a bum cps. You might wanna test the cps to be sure.
Signature
jv3kxj is offline
post #6 of 13 Old 06-05-2007, 11:13 PM
BrunoS
1) check ASD relay.
2) could be the Hall effect sensor inside distributor. it's the CKP sensor.
3) also check fuel delivery (sniff exhaust...should smell like gas if #1 is ok)
next, pull battery cable.
reconnect.
try to start. crank over.
check codes.
if you get code 11, it's the sensor inside the distributor.
other codes...check with forum.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #7 of 13 Old 06-06-2007, 06:43 AM Thread Starter
Rollin
When we looked it up online it said the signal from the CPS is missing
Rollin is offline
post #8 of 13 Old 06-06-2007, 05:28 PM
BrunoS
quick check: unplug and then reconnect the CPS connector and try to start it. if it does, bad CPS. if not, still possible, but there is a way to check it per factory manual for signal.
BrunoS is offline
post #9 of 13 Old 06-06-2007, 08:37 PM Thread Starter
Rollin
6 hours later................ we narrowed it down to the hall effect sensor. We did a quick test by unplugging it on my jeep, and the same symptoms arose. So we ended up going to the used car recycling center to get the sensor, but they made us buy a whole distributor so now we have a refurbished distributor and a running jeep
Rollin is offline
post #10 of 13 Old 06-07-2007, 05:49 PM
BrunoS
awesome.
a failed distributor sensor (only up to 98 so year) will give a code 11, and only after this sequence of steps:
unplug battery
replug battery
crank over motor (it won't start)
pull codes
it will show a 11 and then 55.
the 11 means the computer has never seen a distributor signal. it will only give you the code if you do the above steps, and if the distributor sensor is bad.
why? because if it fails after the motor has been running, it has already seen the signal from previous driving and won't give you the code 11.
big tip:
when the mopar distributor hall effect goes out, at first the car just stalls now and then. Then, it will just quit during running, but will start after cooling down. it then goes out completely. usually a hot day or idling in traffic this will be most apparent.
BrunoS is offline
post #11 of 13 Old 08-13-2007, 08:42 PM
gtospeeding
Hey, check my thread out.
http://www.jeepforum.com/forum/showt...00#post4082200
Im either have to buy a cam or a crank sensor.
which do you think?
thanks ALOT
Originally Posted by BrunoS
big tip:
gtospeeding is offline
post #12 of 13 Old 08-13-2007, 09:11 PM
BrunoS
bad distributor hall effect sensor. CKP, they call it. around $40, easy to install.
BrunoS is offline
post #13 of 13 Old 08-14-2007, 12:36 PM
gtospeeding
thanks for the input guys, the problem ended up being the camshaft sensor, distributor hall effect sensor or the pick-up coil
everyone seems to have a different name for it
