Quantcast cowl intake help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > cowl intake help
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 09-17-2009, 09:59 PM   #1
lilnapsak
1997 XJ Cherokee
cowl intake help
doing same basic cowl intake as ericsxj. everything is done besides the filter and im worried about correct sizes before i order. is this filter a good size to fit inside the cowl and provide enough airflow, ect
http://www.knfilters.com/search/product.aspx?Prod=RU-5111
[QUOTE=Back_In_Black;12988070]your not very good at trolling.[/QUOTE]
lilnapsak is offline   Reply With Quote
Old 09-17-2009, 10:06 PM   #2
1990JEEPXJ
1990 XJ Cherokee
in erics write up he states the filter he used. i think he also posted the dimensions.
Twin 242's
The 'build' thread
1990JEEPXJ is offline   Reply With Quote
Old 09-18-2009, 12:32 AM   #3
DannyRoark89
DannyRoark89's Avatar
1995 XJ Cherokee
Airaid cone filter Simmit AID-700-430 $31.95
its on summit
sorry im a noob on here still and i dont know how to add pictures or i read some were you had to have a certain amount of posts or something but whatever. i did mine differently though i did not use exhaust tubing like in the other write up i just used the flex duct the entire way. its made by spectre and it was about 20$, but the filter fits perfectly into the cowl, i cut my hole a little small as i did not want to cut into into the rib that separates from the hood. don't know why i just didn't want to so i have to kind of squish mine to get it in but still a sweet setup. good luck man.
you"ll notice a little bit more noise in the cab, but nothing to crazy.
DannyRoark89 is offline   Reply With Quote
Glock Forum
