Quantcast Couple questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Couple questions
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 11-17-2009, 11:31 PM   #1
fupkid
1989 XJ Cherokee
Couple questions
Ive got a 84 cherokee parts jeep it has the I4 np207 TC and a auto tranny.Anyone Know what gears are in this thing?..
fupkid is offline   Reply With Quote
Old 11-18-2009, 03:16 AM   #2
USMC_XJ
USMC_XJ's Avatar
1994 XJ Cherokee
From the stock guide sticky at the top, you could have 4.10's or 4.56's. I think that you will have the 4.10's though.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline   Reply With Quote
Old 11-18-2009, 09:28 AM   #3
fupkid
1989 XJ Cherokee
would 4.10's be better then my 3.55's Im running 35" tires
Old 11-18-2009, 11:33 AM   #4
fupkid
1989 XJ Cherokee
Would it be best to swap gears or just swap both axles.
Old 11-18-2009, 03:38 PM   #5
USMC_XJ
USMC_XJ's Avatar
1994 XJ Cherokee
Yes, the numerically higher gears are better for bigger tires. I need to go from 3:55's to 4:56's when I get the money.
To swap gears would be a lot of time and money, if you can't do them yourself. What rear axle do you have?
The front will be a D30 and is the same axle (vacuum disconnect) and the rear could be a D35 or Chryco 8.25. If they do have 4:56's, then you should definitely do the swap. They are the same axles, just taller gears.
If you do swap them over, while you're at it and have the money, you should change the bearings, front and rear, ball joints, u-joints, ect. in the new axles. That way, you won't have any problems during the life of the jeep.
Old 11-18-2009, 06:32 PM   #6
fupkid
1989 XJ Cherokee
Thanks for all the help.I will probably swap them out anyway the 4.10's have got to be better then my 3.55's lol The parts jeep has flat tires so there is no way of getting under it as it sits. One of these days i will jack it up and see what the tags say.
Old 11-18-2009, 06:34 PM   #7
99Greenmachine
Most likely have 4.10s although it could be 4.56 if there is a tow pkg on it IIRC...
Regardless, they will be better than the 3.55 with 35s
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 11-20-2009, 08:03 PM   #8
fupkid
1989 XJ Cherokee
Tryed to read the tag on it today.Its eather 4.10 or 3.73 I am waiting for jeep to send me a build sheet.
Old 11-20-2009, 10:33 PM   #9
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
In 84 the only option was the D35 without C-clips. Most will agree that it's a better axle than the D35 with C-clips, but NOT the axle to put 35s on.
Front axle would be okay, but I'd swap in a 1-piece axle shaft from a 95+ and the short shaft from a 95+ as well. There's a llink in eth Tech/FAQ covering that swap.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 11-20-2009, 10:39 PM   #10
fupkid
1989 XJ Cherokee
The axle under my jeep right now is a 35 with c-clips and it has handled 35's for along time now.
Old 11-20-2009, 11:15 PM   #11
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Bone stock D35c with 35s? Do you wheel it?
93 Sport
Specs in Profile.
Old 11-20-2009, 11:28 PM   #12
fupkid
1989 XJ Cherokee
Ya when i got the jeep it had 35's on it.The guy that had it before me used to wheel it everyday.I have taken it out alot.I will take your word on it being weak..Ill take it easy till it breaks.
Old 11-20-2009, 11:30 PM   #13
fupkid
1989 XJ Cherokee
I found a guy in town that said if i take the 8.25 out of his yard i can have it for free.All it needs is the disk break set up
Old 11-21-2009, 12:25 AM   #14
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
What year? The 97+ have the 29 spline axles and could handle the 35s unlocked. With a locker, it's still doable, but you have to wheel it smart.
93 Sport
Specs in Profile.
Old 11-21-2009, 08:33 AM   #15
fupkid
1989 XJ Cherokee
Im sure it is a 97+ My parts jeep has the d30 3.73 front and 8.25 3.73 rear.Should i even swap out my 3.55 d30 and d35 for these axles?
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
