This could be a problem - JeepForum.com
post #1 of 3 Old 08-16-2002, 12:15 PM Thread Starter
BrianG
I just went to install new speakers in my XJ, and I go to remove the drivers side speaker. I pull it out, and there is this thing all tangled in with the wires, looks like some spring mechanism with a long arm on it.
I search around and realize it is the thing that holds the door open. So I check where it mounts on the door, and there is a big hole where the nut pulled through the metal.
Now I realize as long as I dont swing the door out and let it stress the hinges it should be ok without it, but should I try and fix it anyway? The only thing I can think to do would be to get some thin sheet metal, and sandwhich on either side of the door metal, then put the bolt through that. I can take some pics if you dont know what I'm talking about. I guess I could also bring the door to a local welder, see what he can do.
1988 XJ - 4.0; RE 3.5"; rear D44 w/ ZJ disc brakes; 31x10.50 BFG ATs; Sanden OBA
BrianG is offline
post #2 of 3 Old 08-16-2002, 05:51 PM
Flanz
I'm not sure what the hole looks like but maybe you could just put on a big washer.
'88 XJ 4.0L Rusty's cat back exhaust with Flowmaster
Flanz is offline
post #3 of 3 Old 08-16-2002, 11:43 PM Thread Starter
BrianG
Yeah I may try to find a few big washers..hopefully the bolt is long enough to go through both.
BrianG is offline
Unknown problem idle problem drunkenmonke XJ Cherokee Technical Forum 6 12-22-2007 11:56 AM
Starting Problem and No Air problem johnflores XJ Cherokee Technical Forum 2 11-12-2006 09:21 AM
My problem with defrost/floor vent problem found ebk04 XJ Cherokee Technical Forum 2 07-17-2006 12:37 PM
Problem starting in warm weather! Anyone has the same problem?? keon XJ Cherokee Technical Forum 6 04-14-2006 07:39 PM
Ran into a problem doing my exhaust.. So now I have problem. XJ4oh XJ Cherokee Technical Forum 5 01-01-2006 04:59 PM
