Could be bad Rod Bearing or oil pump??? - JeepForum.com
post #1 of 3 Old 01-27-2011, 05:58 PM Thread Starter
zrambot
Hey fellow jeep people!
I have a dilema that i can not figure out. I have a stock 1996 Grand Cherokee Laredo I-6. There is a squeaking noise coming from the oil pan. i cant determine if its the oil pump or if its a bearing going out.
I know that if a bearing goes out it will cause a knock, but in this cause im not getting knocking (yet).
As for the oil pump i have no idea how to tell if it is going bad.
Any information would be helpful to me.
Thanks
Zrambot
zrambot is offline
post #2 of 3 Old 01-28-2011, 07:46 AM
AZ Jeff
2014 JK Wrangler
There are cases of distributor shaft bushings squeaking on the 4.0, and that can sound like oil pump issues.
Journal bearings as those found on the crank don't squeak before they fail---they knock.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 3 Old 01-28-2011, 07:41 PM Thread Starter
zrambot
Oh ok! I'll check the distributor. Thanks for the info. I'll let you know what I find.
zrambot is offline
engine , rod bearings
Power Steering Pump Bearing Failure j_dynomite XJ Cherokee Technical Forum 4 08-31-2009 08:03 AM
Rear wheel bearing/axle shaft bearing replacement? kadetklapp XJ Cherokee Technical Forum 4 09-02-2008 01:06 PM
changing water pump bearing? lilseth0014 XJ Cherokee Technical Forum 3 02-14-2008 07:19 AM
Wheel bearing, single bearing or hub assembly? Ski01xj XJ Cherokee Technical Forum 25 02-25-2007 08:10 AM
any tech. info. on changing rear axle bearing (pinion bearing)??????? cg2xj XJ Cherokee Technical Forum 1 07-20-2006 10:45 PM
