cost to replace blown head gasket? - JeepForum.com
post #1 of 17 Old 05-22-2007, 08:42 PM Thread Starter
th3godf4th3r
th3godf4th3r's Avatar
what would be a guesstimate of the price???
th3godf4th3r is offline
post #2 of 17 Old 05-22-2007, 08:48 PM
Mikeand
I think I paid about $36 shipped for a Mopar Performance Head Gasket...And some time to remove the head and other manifolds.....so really not much
Mikeand is offline
post #3 of 17 Old 05-22-2007, 08:51 PM Thread Starter
th3godf4th3r
how difficult was that to remove and replace?? On a scale of 1 to 10??
post #4 of 17 Old 05-22-2007, 08:55 PM
Mikeand
Well im in the process of building a stroker so I had the whole engine pulled out...but I assume one could remove the head with the engine still in the bay...Id say remove the valve cover and remove (mostly likely break) the collector bolts on the header...then carefully remove the head bolts and use some man power (two people) and slowly remove the head....clean up head surface and block and put back on to specs...and bolt everything back up...thats how id do it atleast...maybe a 5 i guess
Mikeand is offline
post #5 of 17 Old 05-23-2007, 05:16 AM
crosschecker
1995 XJ Cherokee
You need to remove the manifolds before you remove the head, don't try and remove it as one assembly. On a scale of 1-10, maybe a 6. As long as you can get the fasteners out, it's just going to be a slow process, but not an extremely difficult one. Get yourself a new head gasket, manifold and valve cover gaskets and a twelve pack.
crosschecker is offline
post #6 of 17 Old 05-23-2007, 07:28 AM
Vaj
It's not complicated, it's just alot of work. For your first time, I'd be conservative and give yourself about 8-10 hours. After that you should be able to do it in under 4 hours.
Vaj is offline
post #7 of 17 Old 05-23-2007, 09:07 AM
XJH-007
XJH-007's Avatar
Is this for a 4.0 in your grand? (avatar) or another rig/motor?
If it's the 4.0..........depending on mileage there's a few other things you should do to "freshen" up the motor while you have the head off.
* Lap the valves ($10.00 for the lapping compound and tool)
* De-Carbon head and valves (free)
* Replace Lifters ($60)
I found it was cheaper to purchase a "top end seal kit" instead of just the head gasket. A head Gasket alone will run you $30 at a local auto parts store. For less than $50 you can get a kit that has literally every gasket above the block. (head gasket, thermostat, valve cover, manifolds)
It's not rocket science...if you can read a manual. Just don't be in a hurry..and have fun with it.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #8 of 17 Old 05-23-2007, 09:23 AM
cmotsvt
On an '88 4.0 the manifolds Can be retracted toward the driver's side. Pulling the manifolds along with the head is def not an option, IIRC the head weighs close to 80# by itself.
Head gasket on a 4.0 is a weekend job or more for a newbie and an afternoon job for someone who has done it before. Its a 6 or 7 on a scale of 1-10
I would guess paying a shop to do it youd be in the $600-800 range.
Lifters should always be replaced with cam instead of by themselves.
You should have the head tanked, magnafluxed, and pressure tested.
cmotsvt is offline
post #9 of 17 Old 05-23-2007, 09:28 AM
cmotsvt
Is this for the 5.9 Grand Cherokee or what? It makes a bit of a difference.
cmotsvt is offline
post #10 of 17 Old 05-23-2007, 09:41 AM
XJH-007
XJH-007's Avatar
Overkill.
***02 WJ Overland
XJH-007 is offline
post #11 of 17 Old 05-23-2007, 01:51 PM
cmotsvt
If youre going to do it might as well do it right.
Changing the gasket if you have a cracked or warped head is a waste of time.
cmotsvt is offline
post #12 of 17 Old 05-27-2007, 12:28 AM
xjpro
What's your symptoms for determine that the gasket is blown??
I see some little oil traces between my 2001 XJ head and block.
As far as I have seen its on the passenger's side lets say like in the middle of the engine!
Is this a common failure on the 4.0?
How dangerous is to keep on driving like that?
Thanks
xjpro
xjpro is offline
post #13 of 17 Old 05-27-2007, 12:41 AM
wojtizzlator
1987 XJ Cherokee
DO IT YOURSELF! its a good way to get a look on things too. good opp. to learn and good opp. to see how some other parts in your enginge look like. i did one in a cavalier and i would rate it at a 7 just because some bolts were hard to get to.
Wojtek
"who needs paved roads when u have a jeep"
87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac
colorado jeep club member # 74
wojtizzlator is offline
post #14 of 17 Old 05-27-2007, 05:01 AM
Reader
XJH-007-
I am brand new to working on cars....So I have some very basic questions:
What is: "Lap the valves" and how do you do it? How do you replace the lifters?
Are there any sites that describe the process?
Where did you get your gasket kit? Mopar or somewhere else?
Thanks
Reader is offline
post #15 of 17 Old 05-27-2007, 05:01 AM
Reader
XJH-007-
Thanks
Reader is offline
Blown motor? Cracked head? Head gasket? Cobrajay XJ Cherokee Technical Forum 4 09-29-2009 10:05 PM
Blown head gasket do I have to rebuild head? XJoutlaw XJ Cherokee Technical Forum 2 08-12-2009 07:23 AM
Blown Head Gasket or Cracked Head (Head is off w/ pic) Spike101188 XJ Cherokee Technical Forum 6 06-02-2008 09:13 AM
head gasket blown? canner178 XJ Cherokee Technical Forum 10 02-09-2006 05:07 PM
Blown head gasket hotrail XJ Cherokee Technical Forum 2 01-09-2005 11:05 AM
