cooling issue - JeepForum.com
post #1 of 11 Old 02-25-2013, 08:44 AM Thread Starter
jwrangler91
cooling issue
I have a 97 Cherokee... 182,000 miles. I am having a bit of an issue with my cooling system.
#1 - My heat is nowhere near as warm as it was a couple of weeks ago. Sometimes it blows cold air, sometimes hot, but typically just unsatisfying warm air.
#2 - When i am moving, my temp is fine (right around 200). If i stop, or get caught in traffic, the temp rises to about 230 degrees, which i am not comfortable with.
I'm thinking a good flush will do it for me. Hopefully that is why the heater core is acting up. Im fine if i have to replace the radiator, but really dont feel like replacing the heater core.
Any ideas?
Thanks
91 YJ- Gone
97 XJ- Gone
99 Grand - Daily Driver
jwrangler91 is offline
post #2 of 11 Old 02-25-2013, 09:28 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Your heater core could be partailly clogged, be sure to remove the hoses and give it a good flush as well. The fan clutch is suspect when temp creeps at idle or in stop and go traffic. Also be sure the fins are open and there are no debris clogging the airflow through the radiator and that your electric fan is operating correctly.
xjfever is offline
post #3 of 11 Old 02-25-2013, 10:06 AM Thread Starter
jwrangler91
If I flush the entire system using a garden hose, will that unclog the heater core?? I was thinking the same thing about the fan clutch as well.
91 YJ- Gone
97 XJ- Gone
post #4 of 11 Old 02-25-2013, 11:08 AM
VBRubicon
VBRubicon's Avatar
Just pull both 5/8"(I think) lines off either at the proportioning valve or the firewall and flush it there. At that point, i'd swap the hoses too if they wern't new. And make sure that valve is moving when you change from hot/cold.
Just saw that you said this is a '97 and probably a totally different set-up on the heater valve....ha!
"Yeah well, that's just like...your opinion, man."
-El Duderino-
Mr. Madison, what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
VBRubicon is offline
post #5 of 11 Old 02-25-2013, 06:55 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
There is no heater control valve on the 97 model. I would flush the core directly though, and make sure it is flowing properly.
xjfever is offline
post #6 of 11 Old 02-25-2013, 07:41 PM
Flyordie
1985 XJ Cherokee
REVERSE FLUSH! Fill the core with 50/50 Vinegar Water also to eat up any calcium and deposits that have formed. You could do the same with the radiator if you like too.
Flyordie is offline
post #7 of 11 Old 02-26-2013, 03:26 AM
oakmckinley
Thems hoses ain't cheap.
I dropped $200 bucks on all new hoses for my XJ this past fall. But if you need them...what can you do.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #8 of 11 Old 02-26-2013, 07:03 AM Thread Starter
jwrangler91
Do i have to flush the radiator and the hoses to the heater core seperately?
91 YJ- Gone
97 XJ- Gone
post #9 of 11 Old 02-27-2013, 02:06 AM
oakmckinley
Just do the heater core. You can use water, not necessarily vinegar or anything else.
1999 TJ
2010 Mustang
post #10 of 11 Old 02-27-2013, 10:49 AM Thread Starter
jwrangler91
Ok... well i'm going to flush everything seperately best I can. If that doesn't work I'm thinking it might be the fan clutch...
91 YJ- Gone
97 XJ- Gone
post #11 of 11 Old 02-27-2013, 02:02 PM
oakmckinley
For what it's worth, I know the fan clutch gets mentioned a lot on here but mine are fine on both my Jeeps.
You plugged heater core is probably causing the slight overheating.
1999 TJ
2010 Mustang
