coolant temperature sensor - JeepForum.com
post #1 of 2 Old 02-26-2007, 08:24 PM Thread Starter
scubaguy19
what does the coolant temperature sensor do, and what happens when one of these goes bad?? i'm working on a 90 4.0 cherokee 4x4, and i'm having intermitent starting problems, one day it'll start, the next day it wont, its weird i think it just likes me throwing money at it
2001 5.0 awd exploder - dd
$400 90 laredo xj - beater
91 Limited XJ - missed
Originally Posted by Centrax
There should be a warning label on the sun visor of those H2's "Warning, not intended for off road use." It's not even a REAL Humvee, it's just a Chevy Tahoe with fugly body panels.
thats hilarious
scubaguy19 is offline
post #2 of 2 Old 02-26-2007, 08:34 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
In short the coolant sensor with work the fuel mixture until operating temp is reached.
weird starting problems like yours could be the Crank sensor going bad. I have a 90 and when mine would do the same thing I could disconnect the sensor, cycle the key to run then off and reconnect the sensor and it would start again.
Here is a link for a manual you wont find in the stores its show how to test all the sensors for the renix system.
http://www.pirate4x4.com/tech/billav...ion_manual.pdf
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
engine coolant temperature sensor konadog MJ Comanche Technical Forum 7 09-25-2009 11:24 AM
Coolant Temperature Sensor se7vn XJ Cherokee Technical Forum 2 10-09-2007 12:17 PM
coolant temperature sensor Ex-Jay XJ Cherokee Technical Forum 2 06-02-2007 02:32 PM
coolant temperature sensor 93_zj XJ Cherokee Technical Forum 7 05-26-2005 11:14 AM
Coolant Temperature Sensor Wiring Bruceski XJ Cherokee Technical Forum 1 03-03-2003 01:35 PM
