coolant temperature sensor - JeepForum.com
post #1 of 8 Old 05-14-2005, 07:05 PM Thread Starter
93_zj
do all years of the xj with the 4.0 liter have a coolant temperature sensor in the thermostat housing? I noticed that there are two wires clipped up by the firewall.
93_zj is offline
post #2 of 8 Old 05-14-2005, 07:08 PM
anony91xj
I believe all the ones after 90 or 91 did, some before did not...I'm not sure if the difference was EFI or something else.
This is not the temperature sender for the guage though.
1998 VW GTI 2.0
anony91xj is offline
post #3 of 8 Old 05-15-2005, 08:44 AM Thread Starter
93_zj
and the wires that are coming off from the fuel injector harness?
93_zj is offline
post #4 of 8 Old 05-15-2005, 04:28 PM
88XJ Ltd
88XJ Ltd's Avatar
According to the Chilton manual, only XJ's with Chrysler's MPI (model years 91-96) have the CTS mounted in the T-stat housing. The pre 91 models had the Renix MPI, which mounted the CTS on the left side of the cylinder head just below the exhaust manifold.
1988 XJ
4.0 L, AUTO, 4WD, Selec-trac.
Dana 30, Dana 35
88XJ Ltd is offline
post #5 of 8 Old 05-15-2005, 04:33 PM
JoBo
Score another one for Chilton My 99 sport has the sensor in the thermostat housing Also there's no sending unit for the temp guage on the rear of the head
JoBo
JoBo is offline
post #6 of 8 Old 05-15-2005, 04:49 PM Thread Starter
93_zj
so the cut wires towards the back of the engine coming off from the fuel injector harness are for what?
93_zj is offline
post #7 of 8 Old 05-26-2005, 01:57 AM
RickyN29
RickyN29's Avatar
So wait, on my 90, what is the sensor with two wires coming off that screws into the radiator? It was my understanding that this was the coolant temp sensor (also controls the aux fan)
Reason I ask is my aux fan does not seem to come on when the jeep gets hot. it turns on fine with the AC, everything checks out fine at the relay, and I also have it wired to an override switch which engages the relay just fine.
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline
post #8 of 8 Old 05-26-2005, 11:14 AM
88xjwheeler
88xjwheeler's Avatar
YUP! The Thermo switch (which is located ON THE RADIATOR) on pre '91 XJ. That is the switch that controls the ELECTRIC FAN. But, I did this: http://www.off-road.com/jeep/cheroke.../radiator.html.
So when I replaced the radiator, it didnt' have a place for the thermo switch, so I purchased an Adjustable Thermostat from Kragens. It's just as good as the stock Thermo switch, but i can adjust it to work the fan at what ever temperature I choose.
Oh by the way, I this also allowed me to add a manuel Electric fan switch (to throw on when ever I want the fan to work without waiting for the thermo switch).
1988 Cherokee Pioneer
Mods include:
Upgraded cooling system to open system, replaced stock temp switch with adjustable thermostat
Mods coming:
RE6130 4.5" SuperFlex Lift & 33x12.50 on Black Rock Crawlers
88xjwheeler is offline
engine coolant temperature sensor konadog MJ Comanche Technical Forum 7 09-25-2009 11:24 AM
Coolant Temperature Sensor se7vn XJ Cherokee Technical Forum 2 10-09-2007 12:17 PM
coolant temperature sensor Ex-Jay XJ Cherokee Technical Forum 2 06-02-2007 02:32 PM
coolant temperature sensor scubaguy19 XJ Cherokee Technical Forum 1 02-26-2007 08:34 PM
Coolant Temperature Sensor Wiring Bruceski XJ Cherokee Technical Forum 1 03-03-2003 01:35 PM
