Coolant Temperature Sensor - JeepForum.com
post #1 of 3 Old 09-04-2012, 05:50 AM Thread Starter
Mrandymike
Ok I was draining the coolant in my 1994 Jeep Cherokee and I noticed that I didn't see the engine coolant sensor on the left side of the engine block. (it should have two wires coming out of it right?). If its not there, would that cause the engine to sputter and stall when it idles? If so how hard is it to install a new one wires and all? Thanks for the help
Mrandymike is offline
post #2 of 3 Old 09-04-2012, 06:57 AM
pokeyxj
The older models (renix) had the temp sensor on the left side of the block. Your 94 has one for the gage on the t-stat housing and one for the computer at the back of the head, left side of valve cover. The sputtering/stall could be the throttle position sensor or air intake control valve. There are many posts on both of these so do a search.
2000 XJ Limited, 4.5 Rusty's All spring lift; 265/75/16 BFG KM2's; 4.0, aw4, 242.
2001 XJ Sport, 4.5 Rusty's lift, 32x1150x15 Hankook Dynapro MT's. 4.0, aw4, 231, 8.25 rear with power trax locker.
08 f 150 2.5 lift, 33's, arb.
pokeyxj is offline
post #3 of 3 Old 09-04-2012, 07:23 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Actually, that's bass ackwards. Sender for gauge is at the back of the head. Sensor for the PCM is at the thermostat housing.
cruiser54 is offline
idling , stalling
Coolant Temperature Sensor Ohms maxgordon7 XJ Cherokee Technical Forum 23 07-06-2012 09:16 AM
Coolant Temperature Sensor se7vn XJ Cherokee Technical Forum 2 10-09-2007 12:17 PM
coolant temperature sensor Ex-Jay XJ Cherokee Technical Forum 2 06-02-2007 02:32 PM
coolant temperature sensor scubaguy19 XJ Cherokee Technical Forum 1 02-26-2007 08:34 PM
coolant temperature sensor 93_zj XJ Cherokee Technical Forum 7 05-26-2005 11:14 AM
