-   -   Coolant Temperature Sensor (http://www.jeepforum.com/forum/f11/coolant-temperature-sensor-1413351/)
Mrandymike 09-04-2012 06:50 AM
Ok I was draining the coolant in my 1994 Jeep Cherokee and I noticed that I didn't see the engine coolant sensor on the left side of the engine block. (it should have two wires coming out of it right?). If its not there, would that cause the engine to sputter and stall when it idles? If so how hard is it to install a new one wires and all? Thanks for the help
pokeyxj 09-04-2012 07:57 AM
The older models (renix) had the temp sensor on the left side of the block. Your 94 has one for the gage on the t-stat housing and one for the computer at the back of the head, left side of valve cover. The sputtering/stall could be the throttle position sensor or air intake control valve. There are many posts on both of these so do a search.
cruiser54 09-04-2012 08:23 AM
Actually, that's bass ackwards. Sender for gauge is at the back of the head. Sensor for the PCM is at the thermostat housing.
The time now is 05:30 PM.
