Coolant Spraying out from small leak - JeepForum.com
post #1 of 3 Old 05-06-2012, 08:39 PM Thread Starter
weep
When I got home last night I noticed smoke/steam coming out from under the hood, and that sound of coolant splashing on the ground (same symptoms when the upper radiator hose had a hole in it). I could see where the coolant was spraying out , on the radiator just below where the hose connects on the passenger side near the battery. There are three tiny slits in the area on the side that looks like a black box. Any way to fix this aside from a new radiator? I'm no expert so excuse my lack of terms haha
weep is offline
post #2 of 3 Old 05-06-2012, 08:43 PM
the_weirdo
the_weirdo's Avatar
If it is not the hose, you need a new radiator. I recommend an all-metal unit from DPG offroad or RadiatorBarn.com. Both should get you a much better radiator than stock for ~$230 shipped or less.
the_weirdo is offline
post #3 of 3 Old 05-23-2012, 03:29 PM Thread Starter
weep
It WAS the radiator so I just popped in a new one. Runnin good now. Thanks
weep is offline
coolant , jeep , leak , radiator , spray
CEL - Code P0442 - Evaporative Emission Control System Leak Detected (small leak) Nor10 XJ Cherokee Technical Forum 19 11-16-2013 07:50 AM
Small oil leak? kyjeeper4life XJ Cherokee Technical Forum 1 03-03-2011 06:07 AM
P0456 code evap leak monitor small leak leggament XJ Cherokee Technical Forum 4 10-06-2009 02:39 AM
coolant leak but cannot find lost coolant Jhatke XJ Cherokee Technical Forum 12 03-21-2009 07:54 PM
Small exhaust leak fix? RamboPants XJ Cherokee Technical Forum 7 08-07-2008 12:32 PM
