Quantcast Coolant spill... Problem? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Coolant spill... Problem?
Old 10-15-2008, 12:01 PM   #1
Pat_S
1988 XJ Cherokee
Long story short, I went home and did my everyday chores. After that, I just thought I'd dust off my Jeep til I saw a leak below coming from the right side. I then popped the hood and noticed the coolant spewing (a little hole, size of an ant) out of the bottle everywhere - mostly on the right side of the engine bay. Soon as I saw that, I quickly grabbed vinyl tape and towels in order to stop it from leaking any more, and well, it stopped. It didn't burn the tape at all to my amazement - guess it wasn't that hot.
My question is, will I have a problem due to the coolant spill onto the engine components? Will it ruin anything (i.e. paint, motor mounts, wires, or any of that sort)? I wiped down most of the parts I can reach, but nothing below it. I obviously did this when everything cooled down a bit.
Guess I have to add this: http://www.teamgrandwagoneer.com/parts/Detailed/444.html to my list of parts I need to get. Gee, talk about the love I have for my Jeep and it's problems.
Thanks in advance!
Pat_S is offline   Reply With Quote
Old 10-15-2008, 12:05 PM   #2
kadetklapp
2008 MK Patriot
Nah, it makes a mess but so long as you sop up the large amounts and dispose of it properly, as well as make sure you're not low on coolant, you'll be fine. The spill won't do any specific damage.
**2008 Jeep Patriot Limited 4x4**
60k, *Absolute Rubish*
Former-
2004 Jeep Grand Cherokee Special Edition 4x4 V8.
1999 Jeep Cherokee SE
kadetklapp is offline   Reply With Quote
Old 10-15-2008, 12:17 PM   #3
Pat_S
1988 XJ Cherokee
I know I'm not the only one and know others who encounter this problem as well, but wanted to know if they had any problems in the long run. Thanks for the quick reply!
Old 10-15-2008, 12:49 PM   #4
Zamboni One XJ
If you let it go long enough, the entire engine and compartment should be clean. Then fix the leak. Oh yeah, there is that environment thing too(sarc). Maybe just fix it.
Zamboni One XJ is offline   Reply With Quote
Old 10-15-2008, 02:18 PM   #5
TheNerd
You should replace the bottle. The factory cooling system in an '88 is "closed". The hole you are leaking out of kind of make it an "open" system. As you Jeep heats up, you will continue to leak from the hole (you will leak faster has the hole gets bigger... both from the size of the hole and due to the lower pressures in the cooling system) until you are low on coolant, at which point you will find yourself either running hot, or just plain overheating. Cracks in the pressure bottle are relatively common... but it is not something you should just let keep going.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline   Reply With Quote
Old 10-15-2008, 03:45 PM   #6
Pat_S
1988 XJ Cherokee
Originally Posted by TheNerd View Post
You should replace the bottle. Cracks in the pressure bottle are relatively common... but it is not something you should just let keep going.
Already in the process of that before I drive it again. Is it really common? How does it happen anyway? What causes it to crack? Too old? It's a small, tiny hole (size of an ant) in the center of the bottle.
I never knew or would have to think about ever replacing one - I guess I do.
Huh? Please explain.
Old 10-15-2008, 03:56 PM   #7
kadetklapp
2008 MK Patriot
Just means that the system is now not pressurizing the way it should, and may overheat as a result.
My father-in-law rebuilt an 89 XJ with a 4.0 HO out of a 94 and didn't switch the cooling system over and it overheats if you drive it in the summer. Despite my repeated explaining of the problem, he still hasn't corrected it.
Basically your system requires complete pressurization. Not a big deal if you are just going to limp it home and make sure it doesn't overheat.
Former-
Old 10-15-2008, 09:10 PM   #8
CherokeeErik
omg, call the E.P.A!!!!! j/k Just dont let your neighborhood animals come over and lick it up
CherokeeErik is offline   Reply With Quote
Glock Forum
