coolant reservoir steaming - JeepForum.com
post #1 of 5 Old 04-19-2017, 03:30 PM Thread Starter
Shafty1313
Drove the 89 XJ I6 about 6 miles to the shop today, and at the very end of the trip smelled hot coolant, pulled in the drive, and had steam jetting out of the small hose right at the overflow res. connection..... the half or less full overflow was boiling pretty good. I felt the upper radiator hoses, and they were cool enough to hold in bare hand...... I'm hoping the water pump died..... and it's nothing major. Anyone had this happen? I had no issues prior, did see a little liquid drip from bottom when I parked last week, but it stopped in seconds, and i never could locate a leak or identify fluid ( was on grass, and couldn't find the spot, the amount was so small ) I've been told coolant could drip from bottom of water pump on xj's if it's going bad.
Anyway, it's at the shop at least.... any ideas what I'm looking at possibly being the issue? I think water pump, but my kid's making me nervous, he keeps talking about head gaskets..... ( his only auto experience is limited and only import sports cars though )
Shafty1313 is offline
post #2 of 5 Old 04-21-2017, 03:15 AM
BagusJeep
1981 CJ7
A cool upper hose is a concern, that suggests no water is flowing out of the engine. May be water pump or thermostat, possibly a corroded or silted up head..
Steam from the reservoir connection next to the cap is normal, if the water in the radiator is pressurised and above boiling point it will turn to steam upon exiting.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 5 Old 04-26-2017, 09:01 PM
Mp3zer
1989 XJ Cherokee
Thats the same thing that just happened on my 89 xj i patched it up with some rtv by the return and it sealed it and stopped for a while until i was running on air and a drop of coolant im replacing the whole radiator overflow tank because there was a little crack in the side where the return lines goes i would check that.
Mp3zer is offline
post #4 of 5 Old 04-28-2017, 08:59 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Fix the hose. Refill with coolant.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 5 Old 04-29-2017, 07:52 AM
xjpete
1997 XJ Cherokee
And replacing the radiator cap every couple of years is cheap insurance.
Jeep Grand Cherokee WJ purchased Sept 2014
xjpete is offline
