Coolant question. - JeepForum.com
post #1 of 8 Old 06-22-2013, 03:01 PM Thread Starter
jserna
1987 YJ Wrangler
Coolant question.
Hey fellas, what is going on today? The water pump in my wife's xj just died a few hours ago and had it towed to our house. I did a quick search and could not find an answer, do 98 xj's require any specfic type of coolant? What would you guys recommend.
jserna is offline
post #2 of 8 Old 06-22-2013, 03:37 PM
grainofsalt
Nothing fancy in my '98, Just the normal green stuff.
grainofsalt is offline
post #3 of 8 Old 06-22-2013, 05:01 PM
CoyoteHunter
Ditto on that^^^^. I used Zerex original green concentrated and mixed 50/50 with distilled water.
I just did a full flush a few days ago and threw a $9 stant 195 degree "superstat" in while I had the coolant out.
I found this scan on here, posted by another member. Hope it helps you.
CoyoteHunter is offline
post #4 of 8 Old 06-23-2013, 02:45 PM Thread Starter
jserna
1987 YJ Wrangler
Very cool thank you for the input. that is what I was thinking but wanted to make sure.
jserna is offline
post #5 of 8 Old 06-24-2013, 02:54 PM
Bobplymouth
1997 XJ Cherokee
I read that some coolant makers do not recommend using distilled water.
The tap water here is Va, (cow country), is so full of who knows what, that
I use filtered rain water with my coolant....
Bobplymouth is offline
post #6 of 8 Old 06-24-2013, 04:47 PM
Pats94
Never heard of that. I've been at it a long time and on some pretty exotic stuff, race engines foreign and domestic. Never used anything but distilled water.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #7 of 8 Old 06-24-2013, 06:07 PM Thread Starter
jserna
1987 YJ Wrangler
I saw that too concerning the distilled water. I use filtered water when I mixed the antifreeze. I am glad the job is done. Just out of curiosity, what does the GM stuff have in it that is "bad" for all other makes of autos
jserna is offline
post #8 of 8 Old 06-24-2013, 06:44 PM
dmill89
1995 XJ Cherokee
DexCool is slightly acidic and will eat seals/gaskets that weren't specifically designed for it. Even some GM products had issues with this when they first started using it (especially 1996-1999), it also can turn to sludge if there is air in the system (i.e. a leak) or if it is mixed with any other coolant.
Honestly I'm surprised GM is still using the stuff, Zerex G-05 is a far superior product and is what Ford/Chrysler currently use.
dmill89 is offline
