coolant overflowing in the res... - JeepForum.com
post #1 of 14 Old 04-02-2010, 05:21 PM Thread Starter
Gnl.Weirdness
Drove like 40 miles, engine isnt saying its more then 210, but the check engine light is on and the coolant is way over the fill line... thoughts?
Gnl.Weirdness is offline
post #2 of 14 Old 04-02-2010, 06:03 PM Thread Starter
Gnl.Weirdness
Its gone back down now, but given i have a 2000 head on'er wondering what others think
post #3 of 14 Old 04-02-2010, 06:07 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Guessing if futile.
Pull the codes and post the exact numbers here for comment. Use the technology provided to you with your OBDII system.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 14 Old 04-02-2010, 06:12 PM Thread Starter
Gnl.Weirdness
Yeh have to grab batteries, will post em when i am back
post #5 of 14 Old 04-02-2010, 07:42 PM Thread Starter
Gnl.Weirdness
P0705
Trying to look it up on my phone
post #6 of 14 Old 04-02-2010, 07:48 PM
carenza
thats the code you get when the NSS is going out, Take if off, lightly sand the contacts and fill er up with di-electric grease and reassemble
carenza is offline
post #7 of 14 Old 04-02-2010, 07:50 PM Thread Starter
Gnl.Weirdness
NSS is what? Also would that cause oil pressure to drop a bit when going slow/stopping. Lower then the normal range that is
post #8 of 14 Old 04-02-2010, 09:10 PM
limited
limited's Avatar
1988 XJ Cherokee
Neutral Safety Switch. Doubtful it has anything to do with your issue.
88 Pioneer
4.0 IL6
5 speed
misc. zip-strip mods
limited is offline
post #9 of 14 Old 04-03-2010, 04:36 AM Thread Starter
Gnl.Weirdness
Any thoughts on the coolant issue, wicked paranoid cus it is the 00 head
post #10 of 14 Old 04-03-2010, 05:40 AM
tjwalker
tjwalker's Avatar
A P0705 without any other transmission symptoms is likely the neutral safety switch, as others have mentioned. Here is a link to one of many articles going around that deal with restoring function, which is often successful.
1987-2001 Jeep Cherokees Neutral Safety Switch - Jp Magazine
As for your coolant level in the reservoir, has any cooling system work been done recently? What is the temperature of the coolant gauge in your dash running at? (should be 200-210). Know exactly where your coolant level is right now in the reservoir when hot and cold (it will vary), then watch it closely for changes.
Check oil level, condition and color of oil and look for a "milkshake" color/substance under the oil filler cap. If you see that, it's possible that you have coolant mixing with your oil.
For oil pressure, you have to look at the exact numbers. What are you seeing? The specs for oil pressure for the 4.0 are as follows. If you're in this range, you're fine.
*No less than 13 psi at hot idle
*Between 37-75 over 1600 rpms
tjwalker is offline
post #11 of 14 Old 04-03-2010, 07:30 AM Thread Starter
Gnl.Weirdness
Will check it out today and post back here
post #12 of 14 Old 04-04-2010, 08:06 PM Thread Starter
Gnl.Weirdness
looks to be all good. Wish that write up on JP was a bit more in depth, but I guess I will just give it a shot anyway
post #13 of 14 Old 04-05-2010, 06:50 PM
AZ Jeff
2014 JK Wrangler
Another thing to consider would be a compression test to rule out cooling system pressurization due to combustion gases.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #14 of 14 Old 04-06-2010, 07:09 AM Thread Starter
Gnl.Weirdness
yep, it's all good it was just me being paranoid for the time being cus I have already had to replace the engine once.
