coolant overflowing........... - JeepForum.com
post #1 of 4 Old 10-20-2002, 09:32 AM Thread Starter
jerryhipp
jerryhipp's Avatar
Red face coolant overflowing...........
i've got a 88 cherokee and yesterday i shut it off and when i came back there was coolant all over the street. so i thought i overheated and didn't realize it. so i checked the gauge. not overheating. so i filled it back up and drove around for about an hour with no problems. temp. stayed around 210. shut it off and it started to pour out again all over the street. so i do know two things 1) it's not overheating. 2) it only overflows when it is shut down. i was thinking maybe head gasket, maybe sucking in air and creating a build up? but my friend says he thinks it's my coolant resevior cap seal. so first i'm going to buy a cap because it's cheaper and it can't hurt to try. but i would appreciate any help or advice from anyone.
thanx jerry
p.s. i checked all the hoses for a blockage. nope. and the overflow is coming out of the large hose at the bottom of the radiator, not from the overflow tank.
jerryhipp is offline
post #2 of 4 Old 10-20-2002, 10:15 PM
UglySkunk
UglySkunk's Avatar
my YJ did the same thing bout 6 months ago and it was the water pump
91 YJ currently rebuilding
my jeep can fly can yours
if you don't know about cages or spiked tang sit down and shutup
UglySkunk is offline
post #3 of 4 Old 10-24-2002, 11:56 PM Thread Starter
jerryhipp
jerryhipp's Avatar
thank you ugly skunk. that's exactly what it was. i changed it and the thermostat and it's running great. great advice, i apprieciate it.
post #4 of 4 Old 10-25-2002, 11:01 AM
Apeman
Mine did the same thing and after swapping the fan clutch still did it...it turns ou thtere was still air in the system and was adding unneeded pressure. When the system would "burp" the air out, it would also send coolant out with it...make sure you have no air in the system. It may save you $$ on a water pump.
99XJ - Lifted and whatnot..oh, and its white.
Apeman is offline
What Could Cause Coolant in Oil? Hardt114 XJ Cherokee Technical Forum 18 08-12-2009 06:55 PM
DO you run 50/50 coolant in the 4.0 inline 6 or just coolant Npfiremedic107 XJ Cherokee Technical Forum 11 07-14-2009 04:59 PM
coolant leak but cannot find lost coolant Jhatke XJ Cherokee Technical Forum 12 03-21-2009 07:54 PM
engine coolant overflowing m_w_m XJ Cherokee Technical Forum 6 08-04-2005 06:19 PM
overflowing expansion tank rokclimbertx XJ Cherokee Technical Forum 5 09-08-2004 09:35 PM
