Coolant leaking from block - JeepForum.com
post #1 of 2 Old 03-12-2011, 08:34 PM Thread Starter
Tkitt21
Hi I have a 1999 Cherokee 4.0 4x4 it is leaking coolant from under the intake manifold but its above the freeze plug..the oil isnt gray so i dont think water is getting in it its a slow drip...drip...drip does it sounds like a headgasket or intake manifold gasket or iv been told 99's have a porblem with over heating and cracking the head...what does it sounds like to yall?
Tkitt21 is offline
post #2 of 2 Old 03-12-2011, 08:40 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The 00-01's have the bad head casting. The 99 should be the older head casting. If it isn't a freeze plug it could be the head gasket. There shouldn't be coolant in the intake or exhaust.
xjfever is offline
Where is the engine block coolant drain plug??? ki1022 XJ Cherokee Technical Forum 22 12-31-2015 11:38 AM
Engine Block Coolant Drain Plug FlyinJeep XJ Cherokee Technical Forum 11 01-07-2014 06:02 PM
4.0 Block coolant drain plug 440_Magnum XJ Cherokee Technical Forum 6 01-11-2011 04:47 PM
4.0 overheated, now leaking coolant from back of block. Gsmyth75 XJ Cherokee Technical Forum 4 02-11-2009 06:41 PM
Where is the block coolant drain plug? themow XJ Cherokee Technical Forum 4 11-25-2008 04:10 PM
