Coolant engine drain plug - JeepForum.com
post #1 of 8 Old 08-04-2012, 05:29 PM Thread Starter
Hamid
2015 WK
On 2000 XJ I-6, 4.0L
Anyone tried to loosen the coolant system engine block drain plug on the driver side of the engine, exactly below the intake manifold.
it is a pain, looks like it can be reached with an extension, the plug is a square fit, don't know if there is a tool fits there and what size, I appreciate you all help.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #2 of 8 Old 08-04-2012, 05:33 PM
Diamond-x
1991 XJ Cherokee
There's no reason too, unless your boiling the block.
Diamond-x is offline
post #3 of 8 Old 08-05-2012, 09:14 AM
Weebur
1997 XJ Cherokee
Most square holes in drain plugs are the size of 3/8" extension ends or the 3/8" ratchet. The plugs are pipe threads (tapered), so clean them up good on a wire wheel/brush and wrap a couple windings of Teflon tape on the threads and don't over tighten.
Weebur is offline
post #4 of 8 Old 08-05-2012, 01:49 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Because completely draining the cooling system that way is somehow a bad idea? It's fast, effective, and easy. I prefer using the block drain plug when doing a full flush
1990JEEPXJ is offline
post #5 of 8 Old 08-05-2012, 04:18 PM
Diamond-x
1991 XJ Cherokee
No, it's a great idea. The op is complaining that he can't get the plug out.
Just use the radiator hose connections and save yourself a lot of trouble.
post #6 of 8 Old 08-06-2012, 03:17 AM Thread Starter
Hamid
2015 WK
Really some of you didn't realize what I meant.
I need to remove the plug to drain the cooling sys as mentioned in the scheduled maintenance in the owners manual, that's all.
Anyone did removed that plug in order to flush the cooling sys?.
Thanks for sharing your experience.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #7 of 8 Old 08-06-2012, 06:14 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Actually the ones I've removed have been 5/16" square drive. Ain't that special?
cruiser54 is online now
post #8 of 8 Old 08-06-2012, 06:18 AM
5-90
5-90's Avatar
1988 XJ Cherokee
The early plugs are an 8m/m square drive, which is also just about the same as 5/16". A tool may be readily made from a 5/16" or 8m/m hex key, using only a grinder, and done in about five minutes. (Had to do this for my BA-10/5 transmissions. It's easy.)
Later plugs may take a 3/8" square drive, simplifying the process.
I am unsure if they used a standard tapered pipe thread for this - if they did, it's probably 3/8"NPT or 1/2"NPT, and a replacement plug may be gotten at any hardware store. I'd recommend brass for a replacement - it won't seize.
I'm considering putting a small, cable-operated valve in that port when I overhaul my engine, to simplify thorough drainage of the coolant. Pulling the lower hose doesn't get all of it, you'll have some crud left. Even pulling the plug doesn't get all of it, but it will get a lot more.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
Where is the engine block coolant drain plug??? ki1022 XJ Cherokee Technical Forum 22 12-31-2015 11:38 AM
Engine Block Coolant Drain Plug FlyinJeep XJ Cherokee Technical Forum 11 01-07-2014 06:02 PM
Engine Coolant Drain plug...where? RogueXJ XJ Cherokee Technical Forum 4 02-18-2011 11:56 AM
Do the 4.0L engine have a plug to drain coolant? fortcollinsram XJ Cherokee Technical Forum 2 05-20-2005 07:51 PM
'88 Diff Plug/Block Coolant Drain Plug sroodtuo74 XJ Cherokee Technical Forum 2 09-26-2004 03:49 PM
