Coolant Constantly Overflowing - JeepForum.com
post #1 of 19 Old 06-27-2012, 05:35 PM Thread Starter
aldersonfilm
So I got myself a 1990 XJ recently and have since replaced the expansion tank with a new one and replaced the thermostat as the previous owner took it out for some unknown reason.
Now, however, every time I shutoff the engine after driving, within a few seconds the cap on the expansion tank pops up and hot coolant comes gushing out. The cap is already really finicky, despite it being brand new and does not feel very secure when tightened. Not sure what the deal is but I have had to put new coolant in the jeep about 5 times now. Any good ideas?
aldersonfilm is offline
post #2 of 19 Old 06-27-2012, 05:41 PM
AZ Jeff
2014 JK Wrangler
Replace the tank AND the cap with a new one.
Or better yet, convert to an "open" cooling system.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 19 Old 06-27-2012, 06:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You could try this. Replace the cap with one from Napa. Part number 703-1396.
cruiser54 is offline
post #4 of 19 Old 06-27-2012, 08:01 PM
djb383
Originally Posted by aldersonfilm View Post
........ and replaced the thermostat as the previous owner took it out for some unknown reason.........
The main reason people remove a t-stat is they think it will solve a overheating issue. If removing the stat doesn't correct an overheat, then the problem lies elsewhere. If a new bottle/cap r pukeing, it may be actually over heating. Have u verified temp?
djb383 is offline
post #5 of 19 Old 06-28-2012, 02:22 PM Thread Starter
aldersonfilm
I've been going off the gauge on the dash which appears to be functioning normally. It hasn't passed 210 at all. The strange part is that it ONLY happens a couple seconds after shutting off the engine. I can hear pressure building and then the cap pops off and pukes coolant. It might be possible that I'm overfilling it, though I always fill it up to just above the notch in the post inside the coolant tank. Is it normal for the cap on the expansion tank to be so finicky?? I have to screw it down and then press down for a short turn. If I turn it at all too far it just pops back up and even when it feels like it's on there, if you wiggle it even a little, it'll come loose. But the old tank and cap did the same thing...
post #6 of 19 Old 06-28-2012, 04:47 PM
djb383
Sounds like the cap and bottle r still faulty.....it's got to hold pressure, otherwise, the coolant will boil at about 212. If coolant boils, it will no longer absorb heat. It's the pressure, for the most part, that keeps coolant from boiling.
djb383 is offline
post #7 of 19 Old 06-28-2012, 05:03 PM
Motorcharge
Are you burping the air out of the system after you add coolant?
http://www.lunghd.com/Tech_Articles/...BurpAirMod.htm
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #8 of 19 Old 06-28-2012, 05:22 PM
overlandchris
Have you tried checking to see I'd the hole in the side if the rad filler that goes to the expansion tank is blocked or if the hose is blocked? I have had this happen to me a and it caused coolant to pop the cap in my wj not to as extreme as your situation but similar.
4.7 V8 H.O. The Chevy 302 of Jeep Engines. Roar...
2004 Grand Cherokee Overland, Midnight Blue Pearl.
Rusty's 2" Budget boost, It Goes fast
Project "Shamrock": 96 Cherokee country, black, I6 HO, ZJ 242, 4.5 Rustys, 33" Mud terrains
My build:
overlandchris is offline
post #9 of 19 Old 06-28-2012, 06:53 PM
keepishop
1989 XJ Cherokee
Totally different parts and mechanisms are in use pre 91.
OP, either switch to a higher quality bottle or convert to an open system. I redid mine as an open system and it's been pain-free for a year now.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #10 of 19 Old 06-28-2012, 07:57 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Or simply go to Napa and get a 703-1396 cap for your bottle.
post #11 of 19 Old 06-28-2012, 08:12 PM
austin6137
1990 XJ Cherokee
I have this exact problem, if I fill the bottle to the mark. When i drive the jeep it never overheats, but the moment i park it it pukes out whats in the tank. Now if i leave it low and don't refill the tank its fine, there's still coolant in the system. With it low it mine doesn't overheat, puke coolant its been absolutely fine for two years. I'm not saying you should do it but it's been working fine for me, I never usually let fluids low but it works. I've tried burping it there's no air in it.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #12 of 19 Old 06-28-2012, 08:35 PM
Motorcharge
Same question to you as the OP, have you burped any air out of the cooling system? Link further up for how to.
|SOLD|
| June 2015 COTM |
post #13 of 19 Old 06-28-2012, 09:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Burp the air and use the Napa cap.
post #14 of 19 Old 06-28-2012, 10:09 PM
Paradise XJ
1988 MJ Comanche
From what I can tell at least 33.3% of the respondants here agree.
The pressure bottles are crap (unless you have a metal one), the caps are even worse. Having a proper cap and bottle are crucial with a RENIX XJ.
Both my Jeeps are converted to open. It's not a cure all but it sure does cure the stupid bottle & cap. The new cap is certainly a good start, but I'll give it a year til it craps out again.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #15 of 19 Old 06-28-2012, 10:39 PM
austin6137
1990 XJ Cherokee
Yes as I stated its air free, I'll try the cap. At the moment im not to concerned it doesn't over heat even with the ac on so im not worried.
coolant , overflow tank
coolant overflowing in the res... Gnl.Weirdness XJ Cherokee Technical Forum 13 04-06-2010 08:09 AM
Low Coolant light constantly flashes medicmandan XJ Cherokee Technical Forum 6 12-05-2009 03:33 PM
engine coolant overflowing m_w_m XJ Cherokee Technical Forum 6 08-04-2005 06:19 PM
overflowing expansion tank rokclimbertx XJ Cherokee Technical Forum 5 09-08-2004 09:35 PM
coolant overflowing........... jerryhipp XJ Cherokee Technical Forum 3 10-25-2002 11:01 AM
