converting R12 to 134A - JeepForum.com
post #1 of 7 Old 08-12-2007, 11:53 PM Thread Starter
ar275103
1993 XJ Cherokee
My A/C has been blowing warm air for awhile now and think it just needs a recharge. I know there are kits to convert an R12 to 134A but has anyone on here done it? How hard of an install was it, how long did it take and what can I expect to spend on this
ar275103 is offline
post #2 of 7 Old 08-13-2007, 01:28 AM
tizzdizz
tizzdizz's Avatar
2003 WJ
Most shops would probably tell you you can't just recharge AC, if it's blowing warm that means the refrigerant has leaked out somewhere, and a part needs to be replaced, since it's a sealed system and the refrigerant doesn't get used up. It'd suck to have to do it twice, and pay twice for the refrigerant.
At least in CA, it's not legal to buy R12 unless you have a license to work on these systems, and the fittings need to be changed, along with some other pieces, depending on the vehicle. I haven't done this on a Cherokee, but I'm just speaking from my own experience from when I worked at a shop.
When a customer would bring their car in, we would recharge it. If we couldn't find the problem right away (faulty AC compressor, etc). We would also put in some leak dye, and send the customers on their way, telling them to keep an eye on it and bring it back when it started to get warm again, knowing that we first needed to find the leak/malfunction before fixing the problem. Then, when they came back, we'd be able to trace down the leak, and repair the defect. We wouldn't charge them a second time for refrigerant, which is nice because it's getting expensive!
I know this isn't helpful from a do-it-yourself perspective, but maybe it helps to know a bit about how the mechanics would handle it.
, 4" Zone, 265/75/16 Duratracs, Addco rear swaybar
r: Stock with 31s and a trim. Sold
: 2" on 31s with armor and dents. Sold
74 Nova - 2" drop and disc conv. Sold.
tizzdizz is offline
post #3 of 7 Old 08-13-2007, 06:00 AM
tangofox007
It's a lot easier to take the 609 certification test online and buy some R12. R134a seldoms provides great results in a R12 system.
tangofox007 is offline
post #4 of 7 Old 08-13-2007, 07:47 AM
75SV1
I am no expert, but have looked into this. Some systems convert over from R12 to R134a and work good. On some systems its just an o-ring change, drier and expansion valve plus the scharder valves for R134a. I talked with my neihbor and he said the Jeep's A/C don't blow cold air enough air when converted.
I am converting a Mercedes 240D so I had to learn a bit about the problem. Basically R134a takes more pressure to cool down. This means more head pressure at the condensor. Also, possibly a better compressor and evaporator. The good news is the later XJs used R134a. I'd look at Napa, Advanced etc for a parrallel flow condensor and then change the o-rings (green type), expansion valve (if aplicable or what ever the newer systems use) and a new drier. The condensor should be around $200, the drier $40-80, the o-rings and scharder valves $30. You probably do need to figure out were your leak is at. The evaporator rust out (the one in the dash). You have to take out the dash to get to it.
Tom
75SV1 is offline
post #5 of 7 Old 08-13-2007, 07:58 AM
tangofox007
Don't even think about it!!!
post #6 of 7 Old 08-13-2007, 08:04 AM
88XJ_WI
1988 XJ Cherokee
I changed mine over because the 134a is easier to get. It doesn't cool that great. But my compressor is the original one I think so it's pretty much worn out I think.
and, if you go here you can get certified so you can buy R12. The test is only $15 and it is an open book test, or at least it was when I took it two years ago.
88XJ Laredo
4.0 L, AW4 190,000 miles
96 Grand Cherokee 4.0 145,000 miles
88XJ_WI is offline
post #7 of 7 Old 08-13-2007, 08:06 AM
75SV1
I don't see your point.
Tom
75SV1 is offline
98 Cherokee Leaks 134a Like A Champ CCCHEROKEE XJ Cherokee Technical Forum 13 03-04-2009 04:51 PM
Have I Been Converted To 134a? 88XJSport XJ Cherokee Technical Forum 8 08-21-2008 07:06 PM
converting r12 to 134a rmousir XJ Cherokee Technical Forum 4 07-11-2006 07:46 PM
A/C Conversion Kits to r-134a parrothd XJ Cherokee Technical Forum 6 04-28-2005 08:40 AM
AC 134a Retrofit, General AC discussion RickyN29 XJ Cherokee Technical Forum 1 05-05-2004 01:33 AM
