Control arms and track bar - JeepForum.com
post #1 of 6 Old 10-11-2011, 10:49 PM Thread Starter
dirtybunny
1993 XJ Cherokee
I have a stock 93 cherokee country. I bought it used as a project truck and after buying it found a crappy patch was done on the body where the steering box likes to pop off... I had the body straightened and a good patch and weld done and put on a new steering box and pump.. blah blah blah
anyway, after all this was done I started getting a bad front end wobble at high speeds...took it to a mech and he said I needed new control arm bushings, So I got new bushings and had them replaced, both upper and lower... I got it back and still had the wobble mech told me it was the track bar. I have noticed that the wobble is not as bad if I keep the air in the tires perfectly balanced (what a pain)
I have been researching new track bars and think I might go with rockauto.com as a supplier (local places want way too much)
I have two questions:
1. do you agree that it is probably my track bar and I need a new one?
2. is rockauto a good place for parts like this?
dirtybunny is offline
post #2 of 6 Old 10-11-2011, 11:48 PM
sAe23
1995 XJ Cherokee
1: No
2: Dunno
Have you had it aligned?
Balanced the tires?
What is the condition of all of your tie rod ends?
(Sorry, that's all I got)
sAe23 is offline
post #3 of 6 Old 10-12-2011, 09:03 PM Thread Starter
dirtybunny
1993 XJ Cherokee
Not yet but my alignment doesn't seem to be off by that much
Balanced the tires?
Yes I put on new wheels and tires when I bought it and had them balanced
hmmmm good question LOL I haven't checked
post #4 of 6 Old 10-12-2011, 09:12 PM
Azzy
Check this out, check your Jeep, and let us know what is up
http://jeep-xj.info/HowtoAlignment.htm
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #5 of 6 Old 10-12-2011, 09:26 PM
lilnapsak
1997 XJ Cherokee
wheel bearings could cause death wobble also.
lilnapsak is offline
post #6 of 6 Old 10-12-2011, 10:02 PM
JTM1
1988 XJ Cherokee
Call me lazy, but I prefer to sit or laydown infront of my jeep while someone rocks the steering back and forth while I watch to see what moves that shouldn't. Tie Rod Ends and Track bars are the most common answers.
Justin
88 XJ-Lifted, Locked, and on Jackstands
69 CJ5-In peices
JTM1 is offline
cherokee , rockauto , track bar , wobble
going 4.5" without control arms or track bar ok? Hussler XJ Cherokee Technical Forum 48 01-03-2009 09:50 PM
Rustys Control Arms and Track bar? dirt machine XJ Cherokee Technical Forum 5 01-19-2008 12:05 PM
Lower control arms & Track bar XJMudder XJ Cherokee Technical Forum 1 10-06-2006 06:57 PM
RE control arm drop brackets and Rusty's ADJ control arms xjmatt XJ Cherokee Technical Forum 4 09-30-2004 04:58 AM
Track Bars and Control Arms bluexj XJ Cherokee Technical Forum 4 04-26-2004 01:19 PM
