Quantcast Congrats to our July 2007 Cherokees of the Month: LEAD_NOT_FOLLOW and oohunter04oo - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Congrats to our July 2007 Cherokees of the Month: LEAD_NOT_FOLLOW and oohunter04oo
Old 07-01-2007, 01:00 PM   #1
EricsXJ
The Post man
EricsXJ's Avatar
Congratulations to our Cherokee of the Month winners for July 2007!
oohunter04oo - Stocker Class (click here to see the voting)
LEAD_NOT_FOLLOW - Modified Class (click here to see the voting)
Winner of the Stocker Class
oohunter04oo
91 xj sport, 4.0 HO, AX15, 2wd, D35 rear with stock 3.07gears, 168,xxx miles, rustys intake & k&n, 40 series flowmaster catback, rustys bb, rough coutry shocks, 30x9.50r15, black 15x7 cragar soft 8's, chrome cragar center caps, hurst short throw shifter, 2 hella 500s on bumper, 4 baja offroad lights on rack, homebrew roofrack on surco mounts, matching spare on roofrack, added factory clock, added factory console, drawtite classIII rear hitch, Alpine CDE-9846 mp3 cd reciever, 2 dimond audio 10in subs in custom box, kicker zr120 amp.
Winner of the Modified Class
LEAD_NOT_FOLLOW
1989 Cherokee Laredo
Motor
Golen 4.6L Stroker
9:1 Compression Ratio. Redline right under 6K.
Block: Thermally cleaned and Stainless Steel Shot. Inspected by MPI
process.
Decked, bored, honed with torque-plates and pressure washed. Clevite
cam
bearings and pioneer brass freeze plugs installed.
Crank: Peformance ground 4.2L crankshaft, micro polished and oil holes
chamfered.
Rods: Jeep steel rods, shot peened for strength, resized with new
performance rod bolts.
Pistons: Speed-Pro hypereutectic.
Rings: Speed Pro Plasma-Moly.
Bearings: Clevite Main and Rod Bearings.
Core Plugs: Brass Pioneer core plugs.
Lifters: Comp Cams Hydraulic.
Pushrods: Comp Cams.
Rocker Arms: Comp Cams.
Timing Set: Dynagear Performance.
Cams: Comp Cams. (duration) - Intake: 218˚@ .050˚ Exhaust:
226˚@ .050˚ (lift) - Intake: .493˚ Exhaust: .512˚
(seperation) - 111˚
Oil Delivery: Melling high volume pump, pickup tube and HD Drive
Gasket Set: Fel-Pro Performance
Head Bolts: SBI Performance
Head: '95 HO Head. Combustion Chamber: 62cc - Intake Runner: 155 cc.
Three
angle valve job, bowl ported, valves back cut, new guides etc.
Exhaust: Custom Header/Downpipe/Exhuast
Engine Management: Motec
Cooling: Hesco High Flow Waterpump, CSF 3 Core Radiator, Hesco
High-Flow
T-stat Housing, BRX Hoses, Mr. Gasket High-Performance T-stat.
I'm at aprox 290HP @ 5000rpm and 330ft/lbs @ 4000rpm.
Kenne Bell Supercharger in the works...
Drivetrain/Axels
AW4 w/switch shift mod
NP231
1" TC Drop
Dana 30 Front w/Detroit Locker
Dana 44 Rear
Lift/Tires
5” Hybrid Lift
RE Superflex Adjustable Upper and Lower Control Arms
RE 3.5” Rear Leafs
RE 1.5” Boomerang Rear Shackles
RC Front Springs
OME Shocks
RE Gen. 2 Quick Disco’s
Motion Offroad Tie Rod w/Flip Kit
35” Maxxis Bighorns
15” Crager Streetlocks
Exterior
Motion Offroad Rock Crawler Front Bumper
Custom Rock Rails
LaBarron Hood Vents
ARB Safari Snorkel
Rear Quarter Guards
Metal Taillights w/Led’s
Removed Flares
Bedlined Rockers
Con-Fer Roof Rack
Removable Doors
Yakima Powederhound Ski/Board Holder
IPF Front Headlights
6 Fog lights (2 on bumper, 4 on rack)
Recovery
Custom 4X4 Tow Hooks
48" Hi-Lift Jack
Axe/Shovel
Rear Hitch
Gas Tank Skid
DPG Belly Skid
Motion Offroad C02 Airtank
30ft Strap w/D-rings
Interior
Eagle Journey GPS w/6" screen
Cobra WX 40Chn. CB w/4ft Firestick
Beartracker SAR Radio/Scanner
Dell Laptop w/Custom Laptop Mount
Alpine CD Headunit
800watt Amp w/2 12" Kenwood Subs
Custom 7 switch panel
Whellen Dash Strobes
Whellen Rear Strobe Bar
Whellen Corner Strobes
(use the vehicle for SAR)
Here are the rules for entering the Cherokee of the Month for anyone that is interested in participating next month.
Here are the previous months starting from the most recent:
June 2007 Steamer98 / HeavyMetal
May 2007 gregmondro
April 2007 peeweexj / Ktmracer419
March 2007 lrsmithwhaley
February 2007 Reelrebel18 / RandysCJ (MJ)
January 2007 Grand Fan 4eva
2006 Cherokees of the Year: jfiscus / BlueGerbil
December 2006 Lagooz00XJ / GottaBeJeep
November 2006 delp1213 / commandtoad
October 2006 TwistedSymphony / XJ_Jeeper01
September 2006 White98xj / COJeepin
August 2006 creature / boise49ers
July 2006 Rob92xj / Ex CCS Racer
June 2006 jfiscus / Twisted
May 2006 FernGreenXJ / BlueGerbil
April 2006 tvisXJ / Jeepernick
March 2006 XJ4oh / HeavyMetal
February 2006 Billabong1416 / extankerguy
January 2006 Dave41079 / Fullsizexj
December 2005 homerscj7 / xjrubicon
November 2005 00xj54 / kyro
October 2005 helix / Freerider15
September 2005 fatwreck / flash_gordon
August 2005 Creature / JVRacer04
July 2005 BolognaBlake / wil badger
June 2005 77 renegade / Walton99
May 2005 XJTIMMY! / cbremer
April 2005 Lint / xjj33p3r
March 2005 Scoop0401 / 88eXcellentJeep
February 2005 jeepman75 / fatwreck
January 2005 lbsnowryder / JEEPZZ
December 2004 Lagooz00xj / Sterling90XJ (aka: SilverstoneXJ)
November 2004 local_racer_boy / Xjeepness
October 2004 hondastomper / EricsXJ
September 2004 DMacabre / GottaBeJeep
August 2004 lbsnowryder (MJ) / redjeepguy
July 2004 ugmoe2000 / EnderUSAF
June 2004 Walton99 / creekxj
May 2004 XJ-Ken / Bear549
April 2004 XJ99 / james harmon
March 2004 EnderUSAF / Jason, aka: Jeepin.com
February 2004 thephantum / MSHarnett
January 2004 Rufies97XJ / LOCKED UP
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 07-01-2007, 07:23 PM   #2
Meatroach
1992 XJ Cherokee
Nice rigs guys Congrats!
XJ
[COLOR="Red"]3.5" Warrior coils, Full leaf packs, Skyjacker Quick Disconnects, Rear swaybar delete, Pro Comp shocks, HD Steering stabilizer, BFG AT's, 1" drop shackles, Front tow hooks,Front skid, Warn T-case skid
bcjeepclub.ca
Meatroach is offline   Reply With Quote
Old 07-01-2007, 07:24 PM   #3
XJK
The Guru of Nothing
XJK's Avatar
very nice rigs guys, congrats
-Kyle
XJK is offline   Reply With Quote
Old 07-01-2007, 09:13 PM   #4
88XJSport
1988 XJ Cherokee
LEAD, thats a nice Jeep
And hunter, it was a close race in the beginning, but congrats to you for the win.
88XJSport is offline   Reply With Quote
Old 07-02-2007, 12:45 AM   #5
Prosonic
Lead that is one sick rig. Congratulations to both of you!
Mayhem in potentia
Prosonic is offline   Reply With Quote
Old 07-26-2007, 12:15 AM   #6
KevinKrupp
1994 XJ Cherokee
i like the roof rack!!
[B]-'94 Xj Country
6.5" Rough Country lift with bushwacker fender flares, 35" Maxxis Bighorn Tires, 15" Extreme black steel rims, Rancho steering stabilizer, 40 series Flowmaster Muffler, Custom 1/4" steel Front and rear bumpers with stinger on the front, 4 6.5ton D-Rings, 5' whip on the rear bumper, and a Warn 8,000lb winch on the front bumper, side rock sliders[/B]
KevinKrupp is offline   Reply With Quote
Glock Forum
