Common Prob? Gas tank leak??? - JeepForum.com
post #1 of 9 Old 08-24-2004, 08:51 PM Thread Starter
namtrah
namtrah's Avatar
Question Common Prob? Gas tank leak???
I finished fixing up my floor and there was drilling involved. I thought I punctured the tank, but I lowered it down and could not find any damage from a drill. I get a terrible fuel smell as i drive down the road with the windows open. I filled up the tank and tried to top off and it started dripping gas on the ground. I am thinking a seam or something is leaking. Is this common? My friend has a 1989 and had to replace the tank because it leaks. Just a fluke or something more to it???
04 WJ Laredo-4.0L-NP242-KN Fipk-Borla Exh w/Hi-Flo Cat-6" Lift
namtrah is offline
post #2 of 9 Old 08-24-2004, 09:13 PM
DMacabre
well, if you think you have a tank leak but can't find one, suspect a hole underneath the straps.
88 MJ: some assembly required
98 XJ 2dr: little lift, lotta skidplate
DMacabre is offline
post #3 of 9 Old 08-24-2004, 10:27 PM
RickyN29
RickyN29's Avatar
And if you were just drilling in the area, and now all of a sudden have a gas leak, putting two and two together would make me think you drilled a hole, and not that it i a common gas leak problem.,,
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline
post #4 of 9 Old 08-25-2004, 05:41 AM
russkrs
russkrs's Avatar
Yeah it is fairly common for the gasket at the top of the tank to leak. Fill it up to the max again, then look where it is leaking from, if it rolls down the front of the tank in the middle it is likely the gasket, barring any new holes you may have created, but I would figure if you can't see any, you probably didn't make any.
russkrs is offline
post #5 of 9 Old 08-25-2004, 11:10 AM Thread Starter
namtrah
namtrah's Avatar
Unhappy What did I write
It sure would be nice if everyone read the post first, then answered? I lowered the tank already and checked for DRILL HOLES and any other damage, so I thought I eliminated that in the first post? Anyway, I offroad it rally car style down a firetrail by my house, I bet maybe that the gasket is leaking, that is right where it seems to be coming from. I am thinking of a new tank, but it sure is cheaper to fix the old one with that gas tank repair putty crap, or maybe a new gasket. Thanks for the help
namtrah is offline
post #6 of 9 Old 08-25-2004, 02:07 PM
DMacabre
maybe you put a hole in the filler tube? or the vapor line.
DMacabre is offline
post #7 of 9 Old 08-25-2004, 10:05 PM
XJeepness
XJeepness's Avatar
I know when when i was working on my rig a little while ago. I slipped and smacked the tank hard with a ratchet. Gas started leaking out quickly. Iam thinking that stock tanks are week when they age
XJeepness is offline
post #8 of 9 Old 08-25-2004, 10:52 PM Thread Starter
namtrah
namtrah's Avatar
I think so
I asked this question to see if it was common, sounds like the gasket leak is common. The leak seams to be originating from the central area and leaks to the rear, which is wierd, the back of the jeep is up 2" higher than the front thanks to the AAL? I was looking for a replacement tank. Quadratec has a stock replacement for $110 and $19 for a replacement filler tube/vent tube. I may go that route. I topped it off again tonight...no gas leak, just a terrible, unbearable fuel smell drifting into the cab. You can smell gas wen you are near the rear corner of the Jeep. I wonder if the new tank would have the gasket or gaskets for all teh hoses and fuel pump included, or if they would have to be purchased seperately. I start commuting 52 one way 4 times a week next Monday, so I better find a fix soon!
namtrah is offline
post #9 of 9 Old 08-26-2004, 01:16 PM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
It won't have the fuel pump, it will probably only have the metal tank. You would have to reuse all the hoses or buy new ones. I would look around first though, I gota tank with a brand new Bosch fuel pump installed in it for $50 on another board.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline
Gas tank has a leak TurnerXJ XJ Cherokee Technical Forum 1 01-09-2009 04:45 PM
Common A/c Leak Points? CCFDMEDIK XJ Cherokee Technical Forum 1 09-11-2007 04:04 PM
gas tank leak XJ's4-ALL XJ Cherokee Technical Forum 7 02-20-2007 08:08 AM
Gas Tank Leak 92XJMuddin XJ Cherokee Technical Forum 3 07-29-2006 12:10 PM
Gas tank leak 92XJMuddin XJ Cherokee Technical Forum 4 08-24-2005 12:05 AM
