Quantcast Commanche - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Commanche
TJ 5.25" Speaker Adapters - NalinMFGOfficial Chassis Saver Rust Preventive Truck & Auto UnWant a weekly chance to win $50 in Jcr bucks?
Old 08-20-2004, 02:22 PM   #1
yotakid
Commanche
what axles are peole swaping in there?
what gear for like 37s?
how much lift will fit 37s?
Where do i get that much lift?
will i need to get a lift plus do the soa?
thanx
Justin
yotakid is offline   Reply With Quote
Old 08-20-2004, 06:08 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
It'd be a good idea to do a SOA, and that means fabbing the perches to make them fit. So pick any axle you want and convert that. Basically the same amount of work. If you don't mind the mixed bolt pattern a GM Corp 14 bolt would be a nice axle. I can't remember if the waggy D44's have the same bolt pattern as teh 14 or not?
I'd say a minumum of 4.88's maybe 5.13's for the 37's.
Depends on how much you are willing to chop on the fenders? For an XJ you'd be looking at about 8" with no chopping. So I would guess and say 6.5" and some quality time with a sawzall.
You'll need coils, and more than likely the SOA should net around 3-4" depending on the hieght of the perches you use. You could swap in some Dakota leafs (not the main, all the ones below the main) and that should net about teh right lift.
Keep in mind the extra cost of the SYE and CV drive shaft. A D30 will probably not hold up as well with 37's. You'll probubly need to swap in a D44 up front. You'll need adj LCA and UCA's, brake lines, more than likely a DPA unless you do a high steer conversion. An adj trac bar and extend the Ebrake cable.
I think that covers most of it.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 08-20-2004, 06:44 PM   #3
yotakid
what do you mean by fabbing the perches you mean move them??
Old 08-20-2004, 07:49 PM   #4
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If you plan on doing a Spring Over Axle you will. the MJ is a Spring Under Axle setup. You'll need to weld up some perches for the leafs to sit on to the top of the axle tubes. You'd have to do the same with almost any other axle swap.
93 Sport
Specs in Profile.
Old 08-20-2004, 07:57 PM   #5
yotakid
oh ok thanx for the anwsers!!
i was thinking about a1980+ waggy 44 for the front and maybe a waggy 44 for the rear too maybe
Old 08-20-2004, 08:38 PM   #6
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Waggy front and rear D44's would be a good choice.
If you don't mind me asking, why 37's?
93 Sport
Specs in Profile.
Old 08-20-2004, 08:42 PM   #7
yotakid
umm i dunno
what do you think would be a good size?
Old 08-20-2004, 09:21 PM   #8
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I persoanlly would only go as large as 35's. 4.88's work with them and they are big, but not so big that D44's couldn't handle them.
If you have a long bed MJ then this wouldn't be as much of an issue, but I like a lower center of gravity too.
35's are a bit cheaper than 37's as well. You shouldn't have an issue with a 10 rim on 35's either.
93 Sport
Specs in Profile.
Old 08-20-2004, 09:27 PM   #9
yotakid
yeah that is prolly what i will end up doing lol
Glock Forum
