Cold transmission wont shift out of 1st gear - Page 3 - JeepForum.com
post #31 of 39 Old 06-29-2013, 07:45 PM
skyway0018746
How is the lpg delivered? Through the throttle body? I would say maybe you have a problem with a regulator problem or it also sounds like the timing isn't advancing. I don't have much experience with obd I ( is that what computer you have)
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #32 of 39 Old 06-30-2013, 02:28 AM
O-D
It's OBD II but not showing any codes. Yes the LPG is delivered through the throttle body, and I took it to an LPG mechanic last week to give it a tune-up and have a look over it.
O-D is offline
post #33 of 39 Old 06-30-2013, 12:46 PM
skyway0018746
how long as this been going on before or after lpg installed ?
post #34 of 39 Old 06-30-2013, 02:22 PM
O-D
It's been running fine on LPG for about 3 years.
O-D is offline
post #35 of 39 Old 06-30-2013, 03:32 PM Thread Starter
sAe23
1995 XJ Cherokee
Almost as long as this thread has been alive
(My transmission hasn't acted up for the last couple of years, thanks for asking!)
sAe23 is offline
post #36 of 39 Old 07-01-2013, 01:24 AM
O-D
I thought I'd help you out by reviving your old thread. haha. How did you fix your transmission problem? Was it the TPS, the solenoids or something else?
O-D is offline
post #37 of 39 Old 07-01-2013, 10:23 AM
CitadelXJ
I bought my jeep with a similar issue except I had only 1st and 2nd when the transmission was cold. I had to replace the whole transmission with a junkyard unit. The solenoids didn't work for me either. My transmission was so gunked up I couldn't even clean it properly to do a rebuild.
CitadelXJ is offline
post #38 of 39 Old 07-01-2013, 10:37 AM
skyway0018746
I'm at a loss, I would say its the cap / rotor or the map. That's only a guess.
post #39 of 39 Old 07-01-2013, 06:51 PM Thread Starter
sAe23
1995 XJ Cherokee
Dunno, it just hasn't done it the last couple of winters.
I blame global warming
sAe23 is offline
Transmission not staying in gear, cant shift into gear Jakeman17 MJ Comanche Technical Forum 4 02-08-2010 11:51 AM
wagoneer LTD. wont shift into gear from park Cefalak XJ Cherokee Technical Forum 2 01-25-2010 11:10 PM
Automatic transmission wont shift automaticly for_givn XJ Cherokee Technical Forum 3 12-04-2009 05:01 PM
Transmission acts like it won't shift out of 4th gear 53case MJ Comanche Technical Forum 0 11-01-2009 09:52 AM
1991 transmission wont shift in proper gear corbin9191 XJ Cherokee Technical Forum 6 01-27-2009 11:11 AM
