cold air intake - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > cold air intake
Spartan Lockers FREE SHIPPING Excellent PricesRough Country Jeep Suspension Deals at Rockridge 4WD!Amsteel Blue Synthetic Winch line Free Shipping
Unread 10-24-2009, 10:16 AM   #1
jeepExJay99
cold air intake
I know someone who bought a cold air intake for his f150 and said that he got it for better mpg. Is this true? Any objections?
jeepExJay99 is offline   Reply With Quote
Unread 10-24-2009, 10:29 AM   #2
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
With the VERY minor difference in MPG that you possibly get isn't really worth the money or effort. You can save more gas by adjusting your driving habits
CAI does make nice (?) sounds though
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog 404 portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear,...
http://www.jeepforum.com/forum/f11/h...ternal-973910/
Timo_90xj is offline   Reply With Quote
Unread 10-24-2009, 10:30 AM   #3
Jon00XJ
It is true you can get better MPG with a cold air intake. If you Jeep is a DD and you dont offroad much then i'd say go for it. But they do have there downfalls if you plan on wheeling. They are exposed to water so thy can gt wet and possibly draw moisture into your engine. but there are a few people who routed them into the cowl and use them as a snorkel/cold air intake. If it was me thats what I would do. Search Cowl snorkel or something like that there is a write up some where out there on how exactly to do it.
Jon00XJ is offline   Reply With Quote
Unread 10-24-2009, 10:32 AM   #4
Jon00XJ
http://www.jeepforum.com/forum/f11/a...ite-up-741764/
here is the write up
Unread 10-24-2009, 03:42 PM   #5
jeepExJay99
Read the thread. So if it doesn't improve any on performance, or very little to mpg; then what exactly is the point? Is it strictly for being able to ride through larger depths of water?
Unread 10-24-2009, 07:44 PM   #6
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Yeap, that's pretty much the point on XJs. Performance and MPG improvements are pretty minor, on almost any vehicle. So not really worth it, because fabbing a CAI system isn't free. There is a difference, and on some vehicles it's worth doing it.
On XJs? If you wheel it, then sure go on and do it (a cowl air intake that is). Is it a DD? IMO, not worth it. Sure if you can get the parts cheap, it isn't doing any harm either. But I wouldn't bother.
Unread 10-24-2009, 08:10 PM   #7
2doorxj
2doorxj's Avatar
i did the same cowl intake as ericsxj, i used a cone type filter, i didnt notice any power or mpg differences, but it sounds soo sweeet once you get on the throttle, it cost me about 50 bucks, and i would do it all over again
2doorxj is offline   Reply With Quote
Unread 10-24-2009, 08:20 PM   #8
Haleyrz
you see the biggest improvement with a cold air intake if it is followed by better flowing headers that (for jeep 4.0L) collect at 2.5", followed by a 2.5" downtube to a 2.5" high flow cat, and 2.5" cat back exhaust system. You might see a 2mpg increase with relaxed driving. But with all that you'll see a decent increase in power soooo, thats the main point of them i'd say. The best one i've seen for the XJ is the aFe. The heat shield seals to the top on the hood, and looks like the bottom seals around the bottom of the wheel well...sooooo its decently pretected from water...it seems. Its on my christmas list .
Intake without ABS
Intake with ABS
here are some pictures one installed on Stevieboy's jeep
http://www.jeepforum.com/forum/f11/b...7/index11.html
1998 ZJ Laredo, 4.0L, 2WD "Band Van", Current
1997 XJ, 4.0L, 30x9.50 Maxxis Bighorns, super 44, Sold
2003 WJ Overland, 4.7L HO V8, 6000K HID's, Sold
1996 ZJ Laredo, 5.2L V8, 3" Kolak exhaust, K&N FIPK, 4300K HID's, Sold
http://www.facebook.com/home.php#/pr...27&ref=profile
Haleyrz is offline   Reply With Quote
Unread 10-24-2009, 08:31 PM   #9
Magus2727
1995 XJ Cherokee
The thing is you will be counter productive.
a Short air intake sounds cool so you have your foot on the skinny peddle more often then before. Intakes do help when you open your exhaust. Doing one with out the other does not serve much of a purpose. you will see better throttle response in most cases.
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline   Reply With Quote
Unread 10-24-2009, 08:42 PM   #10
99xjjoe
Has anyone ever ran a jeep 4.0 with CAI on a dyno and proved it dosent make more power?
Didn't the 'check shock' light come on?
99xjjoe is offline   Reply With Quote
Unread 10-24-2009, 08:59 PM   #11
Magus2727
1995 XJ Cherokee
It has been proven that it does make power, a 4x4 mag did dyno runs using the 4.0L out of a wrangler and did a comparison between Intakes.
I believe K&N and the Brute Force one made the highest gains. But those where with a free flowing exhaust (IIRC)
NAXJA Member #2619
