coil spacers with out oem isolator - JeepForum.com
post #1 of 9 Old 02-23-2012, 08:42 AM Thread Starter
asanelli
is there anything wrong with NOT installing to the factory isolator to achieve the lift that i want.
Will there be any adverse symptom of doing this.
asanelli is offline
post #2 of 9 Old 02-23-2012, 08:55 AM
bamstar6
What are the spacers made out of?
My build thread: http://www.jeepforum.com/forum/f22/operation-cherokee-freedom-1336269/
bamstar6 is offline
post #3 of 9 Old 02-23-2012, 09:01 AM Thread Starter
asanelli
poly urathene
asanelli is offline
post #4 of 9 Old 02-23-2012, 09:21 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
There should be no issues, unless you have a sharp end on the coils, or really cheap crappy spacers. Mine are fine after several years of use.
CJ7-Tim is offline
post #5 of 9 Old 02-23-2012, 09:21 AM
Paradise XJ
1988 MJ Comanche
It could be a little "clunk"ier. Why do you not want them??
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #6 of 9 Old 02-23-2012, 10:46 AM Thread Starter
asanelli
to achieve the desired lift that i am after
asanelli is offline
post #7 of 9 Old 02-23-2012, 12:15 PM
bamstar6
I just got some 1" coil spacers and they measure 1.25 and the idolaters are .25 so these are supposed to go on without the isolators. But mine are cheapies I got off eBay for $30 after shipping. But I haven't put them in yet. I would think if they are polyurethane and not like hard plastic or metal, you should b fine. If I put mine on before you do I will let you know how they work out.
bamstar6 is offline
post #8 of 9 Old 02-23-2012, 12:56 PM
dhoge88
1997 XJ Cherokee
what is considered cheap because i priced up some RE 1.75" spacers for $35. good brand/cheap price. are they worth it since ill only have them for about a year and a half before i upgrade?
1997 Jeep Cherokee Country. 2" lift. 30" BFG A/T's
dhoge88 is offline
post #9 of 9 Old 02-23-2012, 02:37 PM
bamstar6
Well I guess I just meant cause I got them off eBay. I haven't put them on cause I think I might need a drop pitman and track bar drop bracket once they go on cause they will put me at 6.5"
bamstar6 is offline
coil spacers, leaf spacers, bumpstops, shackels 4X4XJJeep XJ Cherokee Technical Forum 16 08-19-2008 12:13 AM
Coil Isolator Question JAYSXJ XJ Cherokee Technical Forum 7 01-15-2008 12:49 PM
Do I need spring Isolator with coil spacer TMXONR XJ Cherokee Technical Forum 3 04-17-2007 09:15 AM
Coil Spring Isolator Removal Thayer XJ Cherokee Technical Forum 9 09-08-2005 09:12 PM
whats a coil isolator sizzle-chest XJ Cherokee Technical Forum 3 05-24-2005 04:34 AM
